How much RWHP do the big Cammed australian cars make?
Down here is Aus we use Eddie Current dynos and not the Dynojet, as such they read lower. Now with 260-280 degrees of duration do you mean solid lifter? I would assume so. Let me just say that my engine builder/tuner "Aussie Ls1", has made 512RWHP and run a 10.7 in a manual sedan. Another car that I know of makes 454 RWHP and has run a flat 11 @126.4 MPH. Hope that this sheds some light on the topic.
I do not think they much more power then what we do over here as far as WOT. Kind of like comparing two identical engines but one is injected and the other with a carb. They will both be very close at WOT, but a good injection management system makes all aspects bout infinitely adjustable.
Down under they have the SD tuning for the larger cams figured out very well to make the idle and driveability very tolerable compared to what people call "stock like" around here. Interesting stuff.
Mike Norris
Mike Norris
Try the link below for an example of Aussie engineering skill at its best.
This combined with SD tuning van tame even the biggest cams
http://www.harrop.com.au/site_resour...e_manifold.mpg
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
6600 rpm clutch dump of death Administrator
Keep in mind that the really big cams are using 8TB intakes. The cars over there are 3900 lbs too. So keep the times posted in perspective.
Here is a video of a 242/242 106LSA 105ICL.
I drove a 273/273 104LSA 103 ICL cam in Craig's Ute. It had a 4000 stall and was a load of fun to drive on the street.
users3.ev1.net/~black_ops/video/242-106.mpg
You could also post up on ls1.com.au. I'm sure folks would answer up what HP they are making...
[QUOTE=J-Rod]Keep in mind that the really big cams are using 8TB intakes. /QUOTE]
Exactly. Most of the street cars with ITB's are crazy but not that insane though. Usually around mid 250's with a 106 lsa (big by our standards). Speed density is really a great tool also in helping those cars drive.
