Lifters are in sight ... just got to recover them now
Well I was in the process of lowering my oil pan to drop it today when I stuck my head up in the radiator area and saw my lifters sitting on the plate that sits right below the crank. Unfortunately, they're a ways back in there and i cannot pull them straight out the front. My question is, how much play is in that plate if I were to loosen the front too nuts and let it lower down? If i could loosen the nuts and pull the plate down I'd be able to get the lifters out.
Any help will be most appreciated
Originally Posted by mr2guru
pen magnet.....a really strong one. Or mechanical fingers maybe.
I had pen magnets holding up the lifters when I did the cam swap. But from the time when I pulled the stock cam out (came out very smoothly) to the few minutes later when I tried to slide the new cam in. One of the lifters fell down part way, so when I tried to use the pen magnet to pull it back up, the magnet dropped the lifter.
Anyways I wound up lowering the plate and pulling the lifters out that way. W/ the plate bolted up all the way, there was no way to get the lifters out. I was using a pen magnet but had no way of maneuvering it past the different parts of the crank to get it to the front.
But they're all out now, so I get to start peicing my engine back together tom
Took a lot of luck and a pen magnent tied to a string to fish that bitch out of there, we dropped the socket in the bell housing as well.
Originally Posted by Full-Force
Should have been thinking about that pen magnet before they fell.
Next time just buy you a 4 foot 5/16 dowel rod and cut it in half and slide each piece in the holes.
What holes?
