LS1 Head Bolt HELP!!!!!
Old Aug 25, 2005 | 11:04 AM
Ls1Pwr4's Avatar
Angry LS1 Head Bolt HELP!!!!!
I installed the head bolts on my friends car according to the directions on ls1howto.com. All the head bolts bolted up fine but bolt number 7 on the drivers side seems to be a little springy. I dont know if this is safe or if I need to redo the head on that side??? I really need some help I need to get this car done today!! Can I unbolt that bolt after it has been tightened to spec? Will this blow a head gasket?? Someone HELP???
Old Aug 25, 2005 | 11:07 AM
hellbents10's Avatar
LS1Tech Sponsor
Pull the one out and check for junk in the threads. Or see if it was not threading properly. They are somethimes pretty tough to turn in cause of the loctite/sealer that Gm puts on them.
Old Aug 25, 2005 | 11:08 AM
99ssleeper's Avatar
it would be much quicker to redo that side and make sure you have all the coolant out of those holes than it would be to crack the block or brake the bolt off.
Old Aug 25, 2005 | 11:20 AM
madpwr1's Avatar
all the bolts have already been torqued down to spec according to ls1howto.com ... just the #7 bolt on the drivers side feels springy while the others are solid ... usin felpro head bolts ... would it be possible to just remove that one bolt and check for gunk and reinstall? or does the entire head need to be redone? ... anyone ever had one of their bolts feel a little springy? btw all the holes were cleaned out, and compressed air was also used to get gunk out as well as with a paper towel until it came out clean.
Old Aug 25, 2005 | 02:13 PM
Ls1Pwr4's Avatar
BUMP, Someone know the answer??
Old Aug 25, 2005 | 02:16 PM
Scalpel's Avatar
If the bolt has been torqued to spec, including the different degree rotations it shouldn't be re-used. However, others have re-used them without issue, but the fundamental principle behind a TTY bolt is violated if it is reused after being already torqued to spec.
Old Aug 25, 2005 | 02:18 PM
Ls1Pwr4's Avatar
lets say I just pull that single bolt out can I do that or do all bolts have to come off the head?
cause I can pull that single bolt off the head and then replace that bolt with a new one, but if that will throw the torque on the heads off I dont want to just pull off one bolt.....???
ninobrn99's Avatar
you need to reclean that bolt hole. also lube it with a bit of motor oil to lessen the friction. a few people have been breaking them lately.
Old Aug 25, 2005 | 02:25 PM
Ls1Pwr4's Avatar
but do i need to pull all the bolts out or can i just pull the one out?
Old Aug 25, 2005 | 02:27 PM
ninobrn99's Avatar
all of them. they should all be fine since you havent put any stress on them. studs would've been the way to go from the start though.
Scalpel's Avatar
In all reality, you'd probalby be fine pulling out the old one and putting in a new one.
I have done it once w/no long term side effects.
Old Aug 25, 2005 | 02:54 PM
Ls1Pwr4's Avatar
Thanks for the help!!!
Old Aug 25, 2005 | 04:19 PM
Scalpel's Avatar
I don't condone or recommend the latter but it has worked. I did it out of desparity and it worked fine on a prior LS1 C5.
I later on replaced all of them out of paranoia. No issues ever, just did it for piece of mind.
Old Aug 25, 2005 | 04:26 PM
madpwr1's Avatar
so basically, takin out that one bolt, cleanin it and reusing it is out of the question? i need the car done tonight and i don't have a new head bolt to replace it with ... would i be better off just leavin it like it is?
Old Aug 25, 2005 | 04:43 PM
Ls1Pwr4's Avatar
help??
Old Aug 25, 2005 | 04:51 PM
calongo_SS's Avatar
I wouldn't leave it like it is. If you can't get a all new bolts, I'd just pull the one that doesn't feel right clean out the threads and cross my fingers. You have already been told that the right way to do it is to pull all of the bolts, use new bolts and go through the torqueing procedure. You're asking: "what happens if I do it half assed?" No one is going to tell you exactly what will happen by not doing it the right way.
Old Aug 25, 2005 | 04:57 PM
madpwr1's Avatar
alright everyone thanks for your help, guess i'll be crossin my fingers ... let you know what happens
Old Aug 25, 2005 | 05:56 PM
Scalpel's Avatar
No one will tell you b/c no one can predict what may or may not happen.
Old Aug 26, 2005 | 12:41 AM
madpwr1's Avatar
well i took out the bolt, it was clean, bolt hole was clean, reinstalled it and now it's not springy anymore ... i have no idea what caused that, but seems good now ... gets fired up tomorrow so we'll see if it holds together then ... thanks to everyone that replied.
Old Aug 26, 2005 | 03:05 AM
Boostaholic's Avatar
In this case, I don't think the bolt had a chance to even get sreached to its not-reusable point.
