Couple Noob Piston Q's
Old Sep 5, 2005 | 11:28 AM
cav101's Avatar
Default Couple Noob Piston Q's
i have found most of what im looking for, but i have a couple of what i think are noobie questions, so please bare with me.
LS1, LQ4, LQ9....do they use the same pistons? or is there a different bore, or anything else?
72cc head, and pistons witha 23cc dish, what would the resulting CR be?
again, sorry for the noob type questions, but i appreciate the help.
Russ W
Old Sep 5, 2005 | 11:45 AM
Boostaholic's Avatar
They use the same pistons, they can be different bore (LQ4/9 is 4.00 stock)
What head gasket and bore and stroke? You will need that info to figure out your compression ratio.
Old Sep 5, 2005 | 12:10 PM
cav101's Avatar
lets just say stock HG thickness, stock stroke on a lq4/lq9
Old Sep 5, 2005 | 12:14 PM
cav101's Avatar
6.200 rod, 4.010 bore.
Old Sep 5, 2005 | 12:49 PM
Ferocity02's Avatar
http://www.c5frc.com/calculators/Com...Calculator.htm
Looks like that would make your compression ratio too low, even for FI.
Old Sep 5, 2005 | 01:12 PM
cav101's Avatar
can a guy get some of the back by milling the heads/thinner HG? does cometic make different thicknesses for the LSx?
Old Sep 5, 2005 | 01:14 PM
cav101's Avatar
im lookin to end up around 9:1....but even if it can be brought back to 8.5:1, i think that would be acceptable
Old Sep 5, 2005 | 06:05 PM
cav101's Avatar
1 more question...I am having trouble rods that are 6.200". Cant seem to find them anywhere. You guys have any idea where they'd be purchased from? Would that make a difference in the CR ratio? Sorry again, I just need this info, and searching isnt resulting in the answers i need.
Old Sep 5, 2005 | 06:22 PM
Ferocity02's Avatar
You can use a thinner head gasket. But I would reccomend pistons with less of a dish and heads with a smaller combustion chamber. Milllng the heads is more for when you want to raise the CR for a NA motor. There are cheaper ways to get the right CR from the start, like the right pistons and the right heads.
Old Sep 5, 2005 | 06:29 PM
cav101's Avatar
I know, there is just a good deal right now, and i wanted to figure out if it was worth going after or not. The motor is still in the planning stages, so i am trying to figure out if i can use these pistons or not. Hence all the questions. If I went with 64cc heads, and a slightly thinner HG, that should put me near an area i want to be. That is something i can easily do. I am having a problem finding the correct rods to go with them right now. I dont want to buy something if I cannot not use it....thats why i am here trying to figure it out. Thanx for the help, it all is appreciated.
