Just Talked To Dart.....
Old Sep 13, 2005 | 03:44 AM
  #61
waterbug1999's Avatar
Originally Posted by Brandon
I'm an idiot.. What is all the specs on a stock LS1?
Old Sep 13, 2005 | 09:49 AM
  #62
dame's Avatar
Originally Posted by chicane
I'd love to see TEA, Katech and others do their own magic to a set of these new DART castings. They might just turn out to be the real monsters that we have been waiting for in the larger cid packages.
Do we know if TEA has any intentions on getting a few sets of these to "play" with?
Old Sep 13, 2005 | 04:47 PM
  #63
frisky2101's Avatar
Originally Posted by CTSmechanic
Dart Im sure will make a top quality product However....dont let the bare head price fool you once you have bought theres still work to be done.. and price will vary depending on your performance goals take it from me Im into a set of All Pros for over 3k and thats not counting rocker arms valves or springs..and those are supposed to be an "as cast head"...
Yeah but well at atleast in my case, my father owns his own high pro shop and I get all the work done for free.....
So if you got a hook up or trust yourself to do it it is still a pretty good deal
Old Sep 13, 2005 | 04:55 PM
  #64
frisky2101's Avatar
Originally Posted by tom97ss
I'm thinking the price may be without valves and springs... No mention of valve type or springs.
Their definition of assemble may just mean seats and guides...
I think thats a good idea, a little cheaper but allows flexibilty of component selection.
When I talked to Dart they said that the bare castings will have guides and seats.
SO ASSEMBLED probably mean everything, since the jegs add does say springs good to .600 . But I am not 100% on that have to call Dart and talk to them about what Assembled acctually means
Old Sep 13, 2005 | 07:54 PM
  #65
TAF Motorsports's Avatar
Old Sep 13, 2005 | 08:24 PM
  #66
CTSmechanic's Avatar
Im some what in the same boat as you our in house engine shop is hooking me up pretty nice... WD on all parts a smokin deal on labor( I wouldnt expect it for free) without them and a few others helping me out theres no way I d be able to get my motor done..
Old Sep 13, 2005 | 09:43 PM
  #67
JZ'sTA's Avatar
bore 3.898
stroke 3.622
use gasket size of .040, .045, .054 as they are the more common sizes used. .054 is a good one to use for a stock motor.
-.007 piston height
62 cc's
0 for dish or dome because we have flat tops.
Old Sep 13, 2005 | 10:05 PM
  #68
Originally Posted by JZ'sTA
bore 3.898
stroke 3.622
-.007 piston height
62 cc's
Thanks.. With the .045 HG.. I came out with 11.2. Is that too much?
 Michael S. Palmer
Old Sep 13, 2005 | 11:04 PM
  #69
JS's Avatar
JS
Stock can vary and can be .005 to .007.I think the .045 Cometic is the way to go....Thats what I'm going to run with Arp head bolts..I should be 10.9CR with my setup...
Old Sep 13, 2005 | 11:37 PM
  #70
JZ'sTA's Avatar
Can very but dont forget the - before you enter the number.
-.005 or -.007
Makes a difference.
And 11.2:1 is 100% fine with 93 octane and a good tune.
Old Sep 14, 2005 | 12:11 AM
  #71
Was thinking of getting a set of the TSP 5.3 heads 2.5's this week. What CC's are those?
Should I just sit on the cash and wait for the Dart heads to be released? Dont know what to do!!
Old Sep 14, 2005 | 01:20 AM
  #72
JZ'sTA's Avatar
Call TEA and PRC, then wait for Dart and hope the wait was worth it. lol
good luck on that one.
Old Sep 14, 2005 | 03:14 PM
  #73
Nate_Taufer's Avatar
The numbers are not. But, just think what they will be capable of when someone write's a good CNC program for them...... ?? A good program could realistically pick up 60+ cfm.
The numbers are on their site. Here is linky
And realistically a good porter such as tea will probably only pick up about 18-20 cfm at peak. 60 cfm would put them at 370+ which is not achievable out of a casting of this nature IMO.
http://www.dartheads.com/manager/uploads/LS1Flyer.pdf
Nate
Old Sep 14, 2005 | 03:42 PM
  #74
JS's Avatar
JS
Even out of the box they look great but If u could add 15CFM from 200 to 600 while keeping the runner around 215 I'd think this head would rock.
I wish we had some prelimary dyno #
Some sponsors must have gotten few sets to test....
Old Sep 14, 2005 | 04:10 PM
  #75
strokedls1's Avatar
It doesn't look like these flow any better than my ported 5.3L heads. I don't like the cast runners either since you can get some discrepancies with cast error. CNC gives a much more repeatable final product. The 225 head loses a lot of low end flow over the 205 also, and with flow numbers only going to .550 on the 205's seem like that is where air flow peaked. Just going by flow numbers I would rather get into a stock ported casting or other aftermarket company. I don't see picking up to 370 cfm on these heads either with aftermarket porting. They may turn out to be a good bang for the buck, but I will wait for some real world tests to form an opinion on them.
Old Sep 14, 2005 | 04:47 PM
  #76
JS's Avatar
JS
205 CC and flow 290+
I'd say thats pretty good for an as casted head...
A cookie wheel 1hr and a flow bench will clean them up
Old Sep 15, 2005 | 12:31 AM
  #77
frisky2101's Avatar
Not expecting it for free but well you know how it goes I end up "paying" for it in one way or another, maybe fly him out for the next big Texas NASCAR race. He really gets into that
Old Sep 15, 2005 | 10:17 AM
  #78
SStrokerAce's Avatar
Guys....
first off the difference from the 205-225 heads on the low lift flow it doesn't matter that much for power, but the shape and size of the port will.
The good thing about these castings is the material available in the right spots for porting. In that flyer that has the flow numbers you can see the better bowl shape to start with and then the extra material over the short side. You can get a hell of a good flowing 220cc port out of that 205cc casting without much issue.
Bret
Old Sep 15, 2005 | 11:45 AM
  #79
JS's Avatar
JS
When TEA gets a few sets will see..
I'd like a 215CC runner that has killer numbers from 200 to 600
Old Sep 15, 2005 | 05:48 PM
  #80
I see no problem with tea getting ahold of them. And the short side runner does look like it has a ton of room left for porting.
Hell a mild cnc job could put these puppies flowing like crazy from .2-.4 and still peaking with the big guys heads all with a smaller runner.
Nate
