tr224/224 112 & CC 918 springs...
Old 09-24-2005, 11:12 PM
98SScamaro's Avatar
Default tr224/224 112 & CC 918 springs...
i just got a tr224/224 112 cam with CC 918 valve springs. someone told me the springs i got are not good for the cam. but it came with the kit?!? anyone know if it is ok to run them together???
Old 09-24-2005, 11:17 PM
BIRDONNOS's Avatar
Default 224 and 918's
this is the same setup i have and i have about 15000 miles on mine, it has been sprayed and blown and still runnin strong
Old 09-24-2005, 11:20 PM
98SScamaro's Avatar
ok cool. thanks for the response. i was kind of wondering about that. also i have ls6 heads. you think i should get them ported and polished??? is it worth the money??? or should i just clean them up and slap them on??? im anxious to get it all put on.
Old 09-24-2005, 11:31 PM
BIRDONNOS's Avatar
Originally Posted by 98SScamaro
ok cool. thanks for the response. i was kind of wondering about that. also i have ls6 heads. you think i should get them ported and polished??? well if you have limited funds and know someone who ports then i would say get them to take out the hump around the intake valve and knife edge around the valves and polish the exhaust side. is it worth the money??? if the porting is free or you do it then yes, if not save some money and buy some nice heads with bigger valves or should i just clean them up and slap them on??? you shouldn't have to pull them to install the cam but if they are off then it wouldn't hurt to clean them up i put mine in the dishwasher to clean mine before i ported mine and after i ported them im anxious to get it all put on.
hope this helps
Old 09-25-2005, 12:02 AM
Mike @ New Era's Avatar
Just dynotuned a bolt on car with that cam a couple weeks ago , put out 384 rwhp and 378 tq (stock heads ) and ran 12.4 at 117 with no slicks and traction problems , very nice streetable cam that makes decent power and will work perfect with those springs .
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
Old 09-25-2005, 05:07 AM
98SScamaro's Avatar
Mike
585-865-1832
ok sounds good. thanks for the info.
Old 09-25-2005, 07:21 AM
Schantin's Avatar
CC918's work fine with the TR224 cam. Have about 3K on my setup. As for HP.... I personally dynoed 375/363. The numbers are with a CAI, LT headers, custom tuning, Flowmaster 3" catback, and running dual cat converters. Not the ideal set of mods....but shows how good the cam is
Old 09-25-2005, 07:42 AM
Predator's Avatar
I'm using that setup, so far it's been great.
Old 09-25-2005, 02:16 PM
Krab's Avatar
Those springs will work fine with that cam. I put on a little more than 15K miles on the first set, and just recently replaced them with another set of blue-stripe 918's.
Old 09-25-2005, 03:12 PM
Moderator
davered00ss's Avatar
What is the lift on the cam. 918's are good to .600 lift. If you are going with an agressive ramp rate like the XER .581 lift cams, the 918's will not last as long as with a lower say .563 lift cam. If it is close to the .600 lift the dual springs are better, but the 918's will work.
Old 09-25-2005, 04:53 PM
1 Stout Z's Avatar
918's work! Going on 35,000 miles on 222 .566 112LSA and 918's and mine and still running fine.
Old 09-25-2005, 06:45 PM
Phil'sC5vette's Avatar
Ive had 918 in my car for a year and under 3000 miles. Not really a test, but not problems. I have the same cam on a 114. Your be fine
Old 09-25-2005, 10:16 PM
TPY2KWS6's Avatar
As you can see from my sig I love my 224s
Old 09-26-2005, 06:26 AM
98A4LS1's Avatar
What length pushrods did you guys use, 7.40"?
Old 09-26-2005, 03:55 PM
turbotacoma's Avatar
Yes with stock heads(not shaved)
