What Cam Are you Running with Patriot Stage II Heads?
Hello Guys,
I'm new here. Tried searching the last few days but not much luck with results with running the Partriot Stage II heads, Specs- 2.055" Intake/1.57" Exhaust/64cc.
Was looking to see what results or combination people were running with these heads. The car is a M6, Long Tubes, 4.10's, LS6 intake and a few other bolt ones plus the heads not installed yet. It has very low miles so a rebuild isnt soon but prob nitrous in the future.
The cams I was looking at were the Magic Stick from TSP or the G5x4 but I am afraid of clearance and that these cams might be better as "Cam Only" cams. I didn't consider the T-Rex because a friend has it and I want to do something different. Driveability isn't important.
Thank you
Thank you
Originally Posted by Black02SS
I went with the F13 due to PTV clearance. I didn't want to cut it too close. As far as numbers go, I don't really believe in dyno numbers as they are only a "tuning" tool IMO. Car runs good times at the track and that is all I care about. JMO
Originally Posted by MountainMotor
I'm running a TR224 cam but I'm planning on getting a larger one soon. It runs very smooth but I could go larger.
Originally Posted by Z'mnypit
I to ran the F13 with Patriot stage II LS6 heads. It want an awesome combo.
