where can i find a good deal on heads?
hey guys i am in the market for a new set of heads, i did some research with the search button and i think a lot of guys are leaning towards afr 205's. does anyone know where to find the best deal on these heads? any help would be appreciated.
Originally Posted by WS6FirebirdTA00
search around the sponsors and check out any GP's going on.
Two totally different things unless you're looking for something used.
thanks buddy.....
We have the 205 in stock & we can have a set of PRC 2.5s or 1.5s ready to roll in a day!! The best plan is probably for you to tell us what your goals are so you can select a head that fits your needs
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
You could step up to a ported set of 243 LS6 castings, these heads flow in the 330cfm range.
We port our heads one set at a time for your application, it's what makes us better than the big compines. Heads made to order, we have several differant packages all custom machined and ported for your car. We flow all of the heads we port, you'll get flow sheets and blueprint records as well.
PortPros@sbcglobal.net
