Which heads suit me best?
Old Nov 28, 2005 | 07:13 PM
just-a-z's Avatar
Default Which heads suit me best?
I have an 02 Z-28 A-4. Mods are 232/236 Cam on 112 LSA, 90/90 Setup, UD Pulley, 42 Lbs Injectors, SS Yank 3600 Converter, Full Bolt-ons, and drag radials. Car is not a daily driver and I prefer to run race fuel in it when I do drive it. Thank you In advance.
Old Nov 28, 2005 | 07:39 PM
Q8CamaRo's Avatar
patriot LS6 style stage 2 59cc
30 lbs injector will fit u don`t need the 47
correct me if i`m wrong
Old Nov 29, 2005 | 01:18 AM
just-a-z's Avatar
thanks man, but I hear AFR's are up there as well
Old Nov 29, 2005 | 01:57 AM
Fr33styL3's Avatar
how much power are you wanting to make?
what octane is "race fuel"?
what c/r do you want? sounds like you can afford good gas.
r u looking for a budget head, is money a big factor..?
Old Nov 29, 2005 | 02:47 AM
just-a-z's Avatar
I am looking to make the most possible power out of my ls1. As far as octane, i am not sure exactly, but it is in the 100's. Not sure on the compression ratio, that is why I am asking. I appreciate the reply however, and please feel free to offer up some advice. Thanks
Old Nov 29, 2005 | 02:53 AM
just-a-z's Avatar
I would also like to go bigger on the cam if at all possible? Any suggestions on what will work the best?
Old Nov 29, 2005 | 12:22 PM
just-a-z's Avatar
any advice? Anybody heard of cnc florida stage 3 heads?
Old Nov 29, 2005 | 12:37 PM
Turbo LS1 SS's Avatar
it sounds like u got some coin to spend...
AFR 205s...worked by a credible shop, and a custom cam. Cartek does amazing work with heads/cam ls1s....i'd hit them up...one of the sponsers----->
Old Nov 29, 2005 | 12:47 PM
just-a-z's Avatar
thanks bro, I'll check them out.
Old Dec 1, 2005 | 01:18 PM
just-a-z's Avatar
any other suggestions, What about TEA or Patriot ls6 heads?
Old Dec 7, 2005 | 04:51 PM
just-a-z's Avatar
i called cartek and they seem like an awesome way to go! Anybody else have any other recommendations for a H/C package
Old Dec 7, 2005 | 05:12 PM
calongo_SS's Avatar
ETP, probably the 215 cc, but call them and see what they reccomend. Best heads on the market from what I have seen.
Old Dec 7, 2005 | 05:31 PM
Nittany_marine's Avatar
Go with AFR's and dont look back. Thats what I did. I had them milled down to 59cc's and I couldnt be happier.
Old Dec 7, 2005 | 05:47 PM
just-a-z's Avatar
Stick with AFR's says the MARINE! I just may to that, HOORAH!
Old Dec 7, 2005 | 06:24 PM
waterbug1999's Avatar
Thats what I have read/heard as well.. I would give ETP a call as well....
