Rockers tought to torque down?
SSU's Drunk Typing Whore
Reinstalling the rocker right now on the passengers side.
The first front three went in without any problems. The back ones though are not going as good.
I almost feel like I am going to hit 22 lb ft just threading them in half way down. They are just really tought to thread in. I am afraid that something is wrong???
I turned it over to check everything. That was when I installed the pedistal and two pushrods and two rockers. I probley turned it over 360 degrees or so.
Now I am on the last two for the passengers side.
Should I keep turning it over till they thread in better? I keep turning the engine and building compression but still doesnt want to thread in right.
Also the back ones dont even really line up with the spring - the rockers arm look like they are to far back.
Do I just need to keep turning it?
they won't thread in smoothly? what about when you just thread the bolt in without rocker arms? maybe try doing that so you know its not the head itself. if they still don't thread in, ya might have to pull out the trusty thread tap. its an M8 but for some reason i cannot remember the pitch. maybe a 1.25?
It could be that the lifter is on a cam lobe pushing the pushrod up. Try rotating the pulley like others said until you can pop the push rod and lifter down, and then try torque them. On one of JRPs stickys there is a torque sequence for the rockers.
Here a link https://ls1tech.com/forums/generation-iii-internal-engine/381537-there-torque-sequence-rockers.html
Alright this is really starting to **** me off.
I have been down there for way to long on those rear rockers.
Its the actual bolt that is not threading in. It just stops a little after half way down. Then it gets realllllly hard to thread in so I just back it out everytime.
The rocker arm does not look like its going to line up either. Its to far forward compared to the others.
I just dont get it![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Do I need to get it back at TDC? Seems like it wont be necessary?
I just dont get it
Be careful I busted a bolt on passenger #8 yesterday pulled head today//Do not get in an hurry and go to Chevy house and buy new bolts if needed. look at your threads?? are they stripping ?? Sounds like you might have started to strip the head//If thats the case go to nearest parts house and get a threader for metric #8 I beleive...anyway slow down and take a break ...unles you wan't to pull the head like I did today
I just dont get it
Haha this sucks. Another trip to Sears I guess.
Dumb question: Are the 98 rockers different from the rest of the years? cause I have to switch valve covers.
the 98's should be the same rocker. you can find the tap at any autoparts store. don't get discouraged, your just about done! remember 90% of even car guys out there are scared of changing there own cam out
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Thanks for help though. I am going to run down there now actually and see what I can find.
What size tap? Just want to be sure.
Heres a little update:
Got the tap from Kragen. I had to tap the two back threads. Yes out of all 8 of them the back 2 needed it
But everything went well and I got all the rockers torqued down. Turned the engine over a bunch and everything seems good....
Thanks again for you guys' help. I really do appreciate it
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
