Cam size without Pv clearance issues
And Spin, why don't you tell him what setup you have and why you're running such a tight gasket!
Input came from my uncle on the build as he is an engine bulder for over 30 years.
When you say 'the norm', it is generally accepted outside the LSX forums that .020 is the minimum but on these forums a few builders got it in their heads that .030 is the minimum and is law. Who is to say. My 11k on this build is a very abusive 11k and there is definitely not any carbon build-up in there like the stock set-up had...maybe from the nitrous?
Anyway, just offering what I have for statistical referece or you can just discard it as useless. A properly built motor can do things a patchwork motor can't.
It is my understanding that cometic no longer makes the .027 gasket since no one uses it. I asked why they made it in the first place and they said .020 was acceptable. The minimum is now .033 which is fine with the stock.006-.008 out of the hole piston.
If my set-up didn't blow up by now it is fine. I had the heads off twice to do some head work and all is fine in there.
I went with .040 on my C6 since the displacemnt put me at 11.4:1 and that is where I wanted to be.
BTW, let me emphasise that tight quench will not produce more carbon, but i mean't street driving with stop and go and lots of idling. This in turn, at the long run might cause some clearance issues from carbon buildup.
And Spin, You said nothing wrong, I just wanted the guy to get a clear picture on why you would run such a tight gasket.
