Need help! H/C install
Old Jan 6, 2006 | 08:53 PM
  #121
Lithium's Avatar
SSU's Drunk Typing Whore
My oil pump O ring is perfect.
Old Jan 6, 2006 | 09:15 PM
  #122
Lithium's Avatar
Pump seems dry to me as well. There is no oil dripping out. Felt around inside the pump with my finger and didnt feel any as well.
The spacer fell off the pump before I could see how it was on there. So I cant tell for sure if thats the problem or not.
Everything else seems fine to me. Should I chance it and install it with the spacer in the right spot? and hope that was my problem?
I mean ****...thats has to be it cause of the lack of oil in the pump. I could see how I put the spacer on wrong as well; its definitely possible thats the problem.
Old Jan 7, 2006 | 10:14 AM
  #123
Greg_E's Avatar
Unfortunately, knowing how that spacer was on was a critical piece of information in determining the cause of the problem. All I can say at this point is take your time, double check everything, and hope for the best.
Old Jan 7, 2006 | 02:39 PM
  #124
Lithium's Avatar
Originally Posted by Greg_E
There is a pressure relief valve in the pump. The spring puts pressure on that relief valve. If you look on the right side bottom of the pump, you will see a large Allen head screw. The spring is behind that. If the pump was working when you removed it, and you didn't mess around with it when you had the pump out, I doubt it's the problem. Some people put a shim between the screw and the spring to increase oil pressure. I left my Katech ported LS6 oil pump alone. I figure they know what they're doing, so why mess with it. If you remove the two right side bolts you might be able to slide the spacer out without disassembling everything. While your in there, you might want to remove the pump cover and check to make sure the pump is centered on the crank sprocket/oil pump drive. You can read my thread on that. People have offered a few different ways to accomplish that. When you have the pump cover off, you can squirt some heavy weight oil in there to help prime the pump.
Take your time and check everything twice.
Thats just it. This is the first time I have put it on, so I cant say that it was working before or not.
I bought it off a member on here that ported the LS6 pump himself...
Old Jan 7, 2006 | 11:32 PM
  #125
Lithium's Avatar
Alright the spacer in on correct. The O ring is perfect. Got everything back on. Will fire it up tommarow. I will pray tonight for it to flow oil
If its still not flowing...anyone want a free car? lol.
Old Jan 8, 2006 | 06:03 AM
  #126
Ωmega's Avatar
Good luck!
Old Jan 8, 2006 | 07:39 AM
  #127
98Z28CobraKiller's Avatar
Restricted User
Hey, sorry that I never posted that pic. First, I couldn't figure out how to post a pic quickly and then things got real crazy for me. Did you remove the pump and take it apart while you had it all apart?
Is there a way test the pump w/o actually running the engine?
Old Jan 8, 2006 | 08:35 AM
  #128
CBX's Avatar
CBX
Good luck. If it doesn't work, just buy another pump to be sure.
Old Jan 8, 2006 | 12:34 PM
  #129
Lithium's Avatar
Yeah thats true. I will just slap on the stocker and see it flows.
Old Jan 8, 2006 | 01:12 PM
  #130
ReD_Z28's Avatar
I wish you happy ending for this store, it takes you long time to be done, but hey i have fun reading it every day loll, wish you all the best man
Old Jan 8, 2006 | 01:14 PM
  #131
Lithium's Avatar
lol yeah I am going to get my *** out there right now and finish it up
Old Jan 8, 2006 | 02:05 PM
  #132
mshadow's Avatar
Now that you had your car apart and together a good 10 times wanna come help with my cam swap.
Old Jan 8, 2006 | 03:16 PM
  #133
Lithium's Avatar
hahahaha seriously.
I would'nt mind actually...its the whole NY thing though... kinda far lol.
Old Jan 8, 2006 | 03:24 PM
  #134
CBX's Avatar
CBX
Did you get it back together yet?
Old Jan 8, 2006 | 03:27 PM
  #135
Lithium's Avatar
yeah...but when I drained all the coolant a bunch of **** got in it. So I am going to run down to autozone real quick and get some more. But otherwise yeah its back together; just got to start the ******.
Old Jan 8, 2006 | 03:28 PM
  #136
CBX's Avatar
CBX
I'll keep my fingers crossed.
Old Jan 8, 2006 | 03:39 PM
  #137
Ωmega's Avatar
Same here!!
Old Jan 8, 2006 | 04:13 PM
  #138
jermzz's Avatar
Originally Posted by jermzz
Pcm......
Post #53.
Old Jan 8, 2006 | 04:43 PM
  #139
Lithium's Avatar
hahahaha yeah I know
Old Jan 8, 2006 | 05:10 PM
  #140
Lithium's Avatar
Nothing at all.
Let it run for 5 seconds and nothing came up.
So I am going to have to swap it with the stocker then huh?
I know the spacer is on correct now atleast and still no pressure.
