Need help! H/C install
Old Dec 31, 2005 | 05:10 PM
  #101
Lithium's Avatar
SSU's Drunk Typing Whore
Originally Posted by 98Z28CobraKiller
Wow, I just read thru this thread. My heart is breaking as I am in the middle of a complete engine swap and have never done one before. I hope mine starts when I turn the key and I have pressure.
Thank you for sharing your pain so that others (read I) can learn from it and avoid the pitfalls. I am subscribed.
Good luck!!!
Thanks man. I followed the directions perfectly and turned out I was right when I said everthing was perfect. The PCM though, that was just a dumb error on my part.
But just take your time and be careful and you will be fine
Oh, install the oil pump correctly too
  #102
98Z28CobraKiller's Avatar
Restricted User
Did you have to remove the rear cover? Also, did you check the little dumbbell guy in the front behind the oil pump? Any chance that you messed with the spring in the oil pump?
Old Dec 31, 2005 | 05:13 PM
  #103
Restricted User
Have you been reading this thread https://ls1tech.com/forums/generation-iii-internal-engine/428537-oil-pump-installation-question.html ? I been following that just for the proceedure part of it.
Old Dec 31, 2005 | 05:14 PM
  #104
ReD_Z28's Avatar
good luck man ur there just few step and she will be back agine
Old Dec 31, 2005 | 05:16 PM
  #105
Lithium's Avatar
lets all pray
Thanks ReD_Z28.
Old Dec 31, 2005 | 05:32 PM
  #106
Lithium's Avatar
Have you been reading this thread https://ls1tech.com/forums/showthread.php?t=428537 ? I been following that just for the proceedure part of it.
That spring in the pump...not sure what or where that is. I never messed with it atleast. I ll check that out when I am in there.
That thread is just way to confusing to me I ll read it over again and see if it makes any sense.
Old Dec 31, 2005 | 06:24 PM
  #107
Greg_E's Avatar
I'm in the process of doing H/C as well. That was my thread about centering the oil pump housing on the drive. That would not cause you to have zero oil pressure. Putting the spacer in wrong would. I just took my old pump and made a template of the two mounting holes and the oil discharge port, and then I flipped it. Sure enough, if its in wrong you will pump the oil right back into the pan. Unless you replaced the pump, and the new one is totally nonfunctional, I don't see what else it could be.
Old Dec 31, 2005 | 08:51 PM
  #108
CBX's Avatar
CBX
What spacer?
Old Dec 31, 2005 | 09:02 PM
  #109
Lithium's Avatar
The 2 spacers that you need to put beind the pump so that the Double Roller will clear.
Old Dec 31, 2005 | 09:13 PM
  #110
JMBLOWNWS6's Avatar
Sounds like what my buddie did. It ended up he had the dam crank sensor disconnected.
Old Dec 31, 2005 | 09:46 PM
  #111
CBX's Avatar
CBX
Oh, I see. I just used an LS2 chain so I didn't have to shim.
Old Dec 31, 2005 | 09:56 PM
  #112
CBX's Avatar
CBX
So are you thinking that the pump is too far off the crank and not engaging?
Old Jan 1, 2006 | 06:42 PM
  #113
Lithium's Avatar
No, well I hope not atleast
Its possible to put the bigger spacer on backwards. I realized that it did go a certain way and I spent a lot of time getting it on there right. So I really dont think thats my problem.
Whats this spring in the oil pump?
Old Jan 1, 2006 | 06:49 PM
  #114
CBX's Avatar
CBX
I have no idea what that's about.
Old Jan 1, 2006 | 07:03 PM
  #115
Restricted User
The oil pump has a spring in it that changes the pressure. My SLP Oil Pump came w/ 2 springs. One for stock pressure and one for additional pressure. I will take a pic and post it tomorrow.
Old Jan 1, 2006 | 07:07 PM
  #116
CBX's Avatar
CBX
Inside the front cover of the oil pump?
Old Jan 5, 2006 | 10:18 PM
  #117
Lithium's Avatar
Ok. Got the car apart again. Now I want to do this right the first time. So her is what I am going to look for.
1. Oil pump O ring.
2. Spacer - may of put it on backwards.
3. Spring in pump...still not sure where.
Anything else?
When I took the cover off the chain had oil on it. Everything seemed coated a little bit. Not sure if that means oil was flowing or not cause the rockers had very little oil on them. I am going to get the car jacked up tommarow and get the oil pan dropped so I can remove the pump. But I just dont want to have to do all this over again. So is that all I should look for?
What about that spring? still not sure where or what I may need to do to that.
Thanks again for all of your help. I really appreciate it.
Old Jan 6, 2006 | 05:01 AM
  #118
Greg_E's Avatar
There is a pressure relief valve in the pump. The spring puts pressure on that relief valve. If you look on the right side bottom of the pump, you will see a large Allen head screw. The spring is behind that. If the pump was working when you removed it, and you didn't mess around with it when you had the pump out, I doubt it's the problem. Some people put a shim between the screw and the spring to increase oil pressure. I left my Katech ported LS6 oil pump alone. I figure they know what they're doing, so why mess with it. If you remove the two right side bolts you might be able to slide the spacer out without disassembling everything. While your in there, you might want to remove the pump cover and check to make sure the pump is centered on the crank sprocket/oil pump drive. You can read my thread on that. People have offered a few different ways to accomplish that. When you have the pump cover off, you can squirt some heavy weight oil in there to help prime the pump.
Take your time and check everything twice.
Old Jan 6, 2006 | 05:47 PM
  #119
Lithium's Avatar
Was I supposed to of primed the pump? could that of been the reason why oil pressure did not come up in 7 seconds?
Old Jan 6, 2006 | 07:06 PM
  #120
calongo_SS's Avatar
I didn't prime mine for my cam swap and I saw oil pressure in >5 seconds.
