Need help! H/C install
Old Dec 28, 2005 | 10:52 PM
  #61
oange ss's Avatar
check IGN fuses in fuse box inside the car ?
Old Dec 28, 2005 | 10:56 PM
  #62
Lithium's Avatar
SSU's Drunk Typing Whore
yeah all the fuses are perfect...checked them all seriously 3 times too lol.
Old Dec 28, 2005 | 11:14 PM
  #63
oange ss's Avatar
coil pack harness connectors ?
Old Dec 28, 2005 | 11:16 PM
  #64
Lithium's Avatar
perfect as far as I know atleast.
I picked up a multmeter so I will check that out tommarow.
Old Dec 28, 2005 | 11:20 PM
  #65
oange ss's Avatar
battery's good right ?
Old Dec 28, 2005 | 11:21 PM
  #66
Lithium's Avatar
well for the most part yes it is.
It took a crap on me as I was crankin it the other day.
Got it charged up and seems good.
Old Dec 28, 2005 | 11:30 PM
  #67
ReD_Z28's Avatar
save ur time and do scan to find where is the missing link, blind test want help it at all.wish u good luck......
Old Dec 29, 2005 | 12:04 AM
  #68
Lithium's Avatar
Thanks man I appreciate that
Old Dec 29, 2005 | 12:26 AM
  #69
TopFlite's Avatar
Bump for an update.
Old Dec 29, 2005 | 05:41 PM
  #70
Lithium's Avatar
Good enough lol.
I just got back from work, I am going to get my *** out there and see what I can do.
Old Dec 29, 2005 | 05:44 PM
  #71
ReD_Z28's Avatar
all the best
Old Dec 30, 2005 | 01:16 AM
  #72
ReD_Z28's Avatar
Bump for an update.
Old Dec 30, 2005 | 10:20 PM
  #73
Lithium's Avatar
Took the intake manifold off. Mostly for peace of mind.
Valves are all straight and everything plugged in good. Nothing was loose etc...
Found some metal shavings though in the manifold...got those out.
Other than that everything is perfect...well except for the whole car wont start thing
Old Dec 30, 2005 | 10:24 PM
  #74
Rebelord's Avatar
check all your connections. BTW, I just finished installing my F14 cam today. Sometimes it didnt want to start and I would have to hold the throttle open to get it to start. You can try holding the throttle open for more air...???
Are you getting fuel? Could something have pluged up your fuel lines? Check that. remove the cap on the fuel rail and push in the shrader valve and see if you have pressure.
Ski
Old Dec 30, 2005 | 10:26 PM
  #75
Lithium's Avatar
I have plenty of fuel. Thats not a problem.
Just no spark at all. She turns over fine, but never fires.
Old Dec 30, 2005 | 11:09 PM
  #76
bad6as's Avatar
you dident mess up the timing when installing the cam and roller did ya?
Old Dec 30, 2005 | 11:14 PM
  #77
Lithium's Avatar
Installed it dot to dot.
Hell even took a pic of it and posted on here. Everyone said it was perfect.
Old Dec 30, 2005 | 11:18 PM
  #78
bad6as's Avatar
pick up a new coil.....
Old Dec 30, 2005 | 11:22 PM
  #79
Lithium's Avatar
I am trying to find someone to swap coil packs with.
I dont see why all 8 of the coils would all go out at once though???
Is there anything I could of forgot to put back on? or took off on acident?
Old Dec 30, 2005 | 11:24 PM
  #80
bad6as's Avatar
i know the local pepboys has some msd blaster coils in stock, maby you shorted them out some how, does all the other electrical items still work fine?
