heli-coil failed, now what?
Keensert
E-Z Lock available through mscdirect.com on the internet.
8 mm x 1.25 pitch insert part number is: 99762346
They make a stainless insert as well. I don't recommend stainless steel for this application.
The outside thread on that insert is 1/2 - 13. That should be more than large enough to fix the stripped hole. You will also need the installation tool: 86767381
Cost for both is under $20.
It would be best to remove the head and do this on a Bridgeport or cylinder head machine. If you are very careful about drilling and tapping the hole straight, it can be done in place.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
I have ARP studs, I dont have to take them off right? I should be able to lift the head from them and slide over right? Its a Camaro.
Have you shipped these in to us yet?
