GMPP Cams (Hotcam, LS6, ASA, Cup), what lobe?
OK, I think I found one for the Hotcam:
Intake: 279-219=60
Exhaust: 287-228=59
Not as slow as I would have thought (quite a few Lunati lobes check in at this range).
Intake: 279-219=60
Exhaust: 287-228=59
Originally Posted by alans02z
Have you checked the GMPP catalog? On some of the cams in there they have alot of info, or used to have alot. Are you debating using one of these? Again?lol
Originally Posted by TAF Motorsports
Grand Am Cup
Advertised Duration Int. : 294
Advertised Duration Exh. : 306
Duration @ 0.050" (I/E) : 239 / 251
Lift (I/E) : 0.570 / 0.570
Lobe Separation : 106
55/55, getting into XE range.
well, getting married soon so modding has taken a back seat! Alot of people trash talk the asa. For this reason i would like to see what its capable of. The more i read on here the more i want to put a huge cam in. But i think the most important thing is having a setup that works together. Hence gmpp cnc ls6 heads + asa. I would rather have the asa that may make 15 rwhp less than the huge cam but never have to worry about valvespring maintenance or having to take my stock bottom end to 7k rpm to make power. I think this combo would work well together and your engine will live for a long time.
ASA
From: https://ls1tech.com/forums/generation-iii-internal-engine/439678-measured-my-asa-here-s-some-numbers.html
Published specs; 225/236 @ 0.050 verified installed
0.525/0.525" verified installed @ 0.308/9" actual lift
110 degrees LSA verified installed
What I measured;
Base circle 0.760"
Intake lobe centerline 108 degrees
Exhaust lobe centerline 248 degrees
Duration at 0.006", I=282, E=292
Ramp rate = 56
What I measured;
Base circle 0.760"
Ramp rate = 56
