How much preload with adjustable rockers & stock lifters?
I am working hard to make the stock covers work without spacers. The front and back rockers are going to be the critical ones. The rockers seem to be well made and lightweight. I think patriot is selling some other rockers now though. I was originally going with a solid cam so I thought I would use them anyway. I wound up with 7.1 pushrods and .040 washers under rocker stands to get geometry close.
Remember the standard for steel small block engines was 1 full turn. That was adjusting the stud at the fulcrum, or center of the pivot point. If you are adjusting the screw at the top of the pushrod, it may take more turns. The looser you set them, the more rpm they will go without floating, but they may make noise. One turn at the pushrod should be good, if they are noisy when the engine is hot, tighten to 1.5 turns
Originally Posted by MOTRUBL
How about setting preload with J2K Jesels and Morels??
