Hype surrounding ET Performance heads
It's not BS, it's called clarification. The point of the thread is to educate the consumer that the 479rwhp Mustang dyno number was false. The customer dynos 373rwhp/350rwtq with cam and stock heads on a Mustang dyno. Then he adds ETP 215 heads, changes to an Ed Curtis cam, ports his throttle body and re-dynoes 402/369. A solid gain, but not the stuff legends are made of. Like I said, based on the flow numbers, the ET heads look promising, but let's bridle our enthusiasm a little until more dyno and track numbers are out.
Personally this thread is BS. Being a MODERATOR, you should have more class than this to post something up like this.
Dennis had stopped by today and talked with us as just a concern to see what we thought of the whole thing. So yes, are we aware of what has happened in his case.
Posted by Paulz2820
nah i agree with patrick. people need to know that car didn't make 490RWHP with ET heads. "corrupted files" my ***, its called propaganda and they fooled people by saying there heads made 490 when in reality it was 402RWHP! i would be so pissed if i just spent 3 grand on a set of heads comparable to dare i say $1500 patriots. regardless people need to know the claims orginally made by DTC and ET Performance were false who cares if it was because of a computer glich? I as a consumer deserve to know!!
We have dyno tests that we had never posted, we would have thrown those out all over the boards at first, but we did not. As far as ET or W2W going out and making a "ringer" to throw out huge dyno numbers is out of the question. Don't you think that he would have put down better numbers when he went back?
Posted by RyanJ
That's pretty harsh words there. Implying that ETP and/or W2W knowlingly advertised false numbers for whatever reason? ETP and W2W have neen around for a long time with ZERO complaints from customers (one of which would be GM).
Thank you, at least someone has a clear head.
I think it's a honest mistake where the manufacturer of a new product was eager to show some real world results to the community at large and generate interest in their product. No one can fault them for that, but looking back maybe they jumped the gun a bit and should have waited for similar results to surface to back up the claims. Even though I currently run the AFR 225, I'm still curious to see some results of the ETP heads on large strokers.
The dyno thread is there for all of us to see. This thread's intent seemed very editorial in nature (the title in itself uses the word "hype"), despite the tech info involved.
The dyno thread is there for all of us to see. This thread's intent seemed very editorial in nature, despite the tech info involved.
i dont own either set of heads
I could have bought any set of heads out there for my set-up. I trust Ben and G-Force. They love these heads and with everything ET has done I want a set. Say what you want, these heads flow. But NO MATTER how good the heads flow, if you don`t have everything to go with it. It doesn`t matter. I`ve got a good feeling about the numbers my car is going to put out. Wait and See.
First, Patrick's posts are generally well thought out and insightful.
Second, I don't think one dyno of one head has caused the stampede to ET heads.
Third, it is reasonable to think ET would get a head right, since they were top line porters before making their own heads.
Fourth, ET heads fit in a top line of heads which would include the C5R, AFR, CNC Dart, and a CNC World, although I don't think World will make that directly.
That the ET heads are 11 deg probably gives them an advantage. The combustion chambers certainly look like a leading edge design (something about making power there). However, racing rules will make an 11 deg head not an option for some. Others will find availablity and price point them elsewhere. And the C5R/LS7 ports are probably much better than any cathedral port head, ET or otherwise.
The only ET heads in direct competition with AFR, Dart, and ported LS6 and 5.3 heads are their 215 and 225 models. The rest fit a different segment no well served otherwise.
Net, ET heads are probably the highest performance unrestricted LS1 heads for most applications. And maybe a little over-hyped also.
Yeah like there isn't a ton of 12:1 CR 383 and 370 cubed motor's making less power through their automatic's.
And let me tell you that 4.000 bore is such a hugh power maker over our 3.898 bore.
Can someone recomend me a really BIG Cam?
And Howmuch Horespowur will i macke ?
What about the other C5 he did that was 470-480rwhp?
