Hype surrounding ET Performance heads
Regardless, THIS thread is more blind "hype" than any one I've seen. I trust Patrick and have a load of respect for him in this community (way back to 99-00 on LS1.com), but I think the thread is wrong. If you really just wanted to get the word out, I think you could have named the thread something different and just posted a link to the dyno thread.
Any who, more tests will show up and we'll end up back in the middle of the bell curve as always (albiet a higher horsepower one
). Same thing happened with lids back in 99 and TR cams 2-3 years ago, and AFR's last year.
Yes, someone send this guy a pair of heads. Craig? Anyone have some for a project not done yet?
Oh and for the record I am still up for the comparo
I can take it to Mikey at Rapid for the tune/dyno work
We work directly with most of our competitors and just do not have a reason to lye about our product. It shows itself. As far as I am concerned, Patrick has an alterior motive and shows that plain and simple. We are not looking to be "protected" by having our name listed on the side in the list of sponsors. If we were misleading people, you would have heard that a long time ago. It is not like we only have 5 or 10 sets of the seads out there, more like 150+. This is kinda like a little soap opera to a select few, I can see.And as far as a previous post regarding "flow numbers are not everything" That is preaching to the Choir. If people did not ask, I would have never even disclosed that information. No, that is not absolutely the only horsepower factor, But tell me one guy out there that is going to spend a couple grand for heads and not take the flow data into consideration.
Thanks Patrick! Glad to see you could enlighten us.
Cary
thanks,
Cary
Yes it probably would, Sometimes we are on the good side of things, sometimes not. THere are some very good cylinder head guys out there that can really work some majic out of a stock head. We just had to offer something to every level out there. We have a 300+cfm 215 head, a few different ls7 heads and a 430 cfm canted valve head, all from the same casting. We do offer a lot of diversity. We are not trying to lauch a propaganda campaign, just a new line of cylinder heads, something I wanted to do a few years ago and just did not have internal support.
Props to ETP for stepping the **** up and putting their foot down and standing behind their product in this thread that shouldn't have even appeared in the first place.
Personally, I applaud ET Heads for competing with the larger cylinder head companies. Everyone already knows that AFR was created by God Himself, Joseph didn't do carpentry work at all, but actually designed their 205 and 225cc heads, Jesus turned water into wine and turned a block of aluminum into said heads, ported and flowed them on the SuperFlow 10000, and Mary answered the phones.
Good job trying to deflate the problem
Attacking AFR is no different than the attacks towards ET. IT doesnt help the situation one way or the other.And Ryan J your reponse to Kraest shows your bias in the situation. I figure someone spouting off the virtues of not bashing would "practice what he preaches" a little better
Patrick, you need to lock your own thread.
If Patrick did not make this post then I would have never seen this info (especially the various links that have even better info) as I rarely visit the dyno section. He came off a bit over-zealous but I think that is due to him being releaved he did not waste his money on AFR's. But cut the guy a break, you are making him out to be a politician with all of these hidden motives when he was a just over-zealous and chose some poor wording in presenting this.
When I get heads I will probably go with AFR's or ET's as they look top notch. There will be many more dynos and many more debates that help make my decision.
At the end of the day though, I bet the ET heads are gonna walk all over the competition.
thanks
dennis
i never saw the first post of 479hp,but atleast the guy came clean about it,if the file had a problem it's not like he did it to make his car sound more then it was.
That does not discredit them, just tells me that every dyno trick in the book was pulled to hit his numbers.
