loosing oil but no leak
need help finding a good mechanic in the area. my ls1 is loosing oil, about 1 qt. or more per 3000 miles, but there is no oil spot on ground or leaks that i can see on the bottom of the engine. also, sometimes get a strong oil smell after starting engine. any ideas about the problem and where i can get this checked out?
Originally Posted by jb007
leesburg, va. if that's all that the problem is, how difficult to fix.
What oil are you running? I was running a thin synthetic. 5-20 redline I think it was. I came to the conclusion that I was loosing it through my pcv into the intake. Maybe try running a thicker oil and see if that solves your problem. Its alot easier than ripping into your engine.
i use a 5w or 10w 30. i usually use castrol and have actually tried using diff. weights but no significant effect. thanks for the input. back in sept. i started my car one morning and the valves started clicking. this was the first and only time it happened. i monitor the oil level weekly and change every 3k miles. so i'm think that it definitely is an issue with the valves or seals.
Originally Posted by NoGamesLS1
Well that should be a "fun" project good luck
