Will 1.8 ratio rockers/stock cam make the exhaust sound cooler
will adding 1.8 ratio rockers/stock cam give me a lopey sounding exhaust with stock cam?
they claim 8-10 HP gain so I can actually expect what about 3HP, mainly looking for cooler sound.
Thanks
Thanks
Thanks
__________________
Thanks
__________________
No it will not. Actually it made things a bit quieter and smoother. Did help in bringing up the torque. At the time I installed them I felt a decent gain. And now with F/I they have brought the TQ & HP closer together.
Back when I installed them I was not real heavy into modding and then I changed. If you plan on doing more down the road I would go with a cam and upgrade springs ect. Vs the arms. Then you will have your many choices of sound and where you want the power.
If you use 1.8 rockers and you get a cam in the future, the 1.8's will severly limit your cam choices. For the money 1.8 rockers as a power upgrade are one of the worst investments.
I had them and they were worthless when I wanted to get serious with a different cam. Even the 220/224 cam I had first couldn't use the 1.8's. Stay away from Harlan Sharps/SLP rockers regardless of ratio. Trust me.
Originally Posted by badmfkr
been studing up on cam install , mite be more than I can handle myself.
Thanks guys for infor
No Adding Larger Ratio Rockers Will Not Increase The Idle Sound, But Will Affect Cam Opening And Closing, As Well As Duration A Little Bit. The Rockers To Do This With Is The Crane Cams Quick Lift Rockers. Part #144759-16. This Is A Complete Kit With Rockers, Pushrods, Guideplates, And Studs. They Are Price But These Rockers On A Stock Cam Ls1 Will Produce Between 18-25hp To The Rear Wheels(no Joke), And Even More If You Use A Crane Quick Lift Profile Cam. Im Not Trying To Sell You Rockers, Just Answering Your Question. Don't Believe Everything You Here About The Ls1 Rocker Arm, The Cranes Really Do Work, Ask Some Of You Top Engine Builders Out There, They Will Tell You. I've Installed Plenty Of Them To Date, And Had No Complaint As Well As Nothing But Power Increase As Well To. Good Luck!
i changed my stock rockers to 1.85s a few years ago. i gained like 10 rwhp and 14 rwtq.
it didnt change the exhaust note at all. it did make the engine sound like a sewing machine.
well i cammed my car. needless to say the 1.85 had to go and stock rockers are back on.
dont waste youre money is the moral of this story.
![Gay!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_rainbow.gif)
i have yet to see anybody gain that much.
my graph with 1.85s is above.
Originally Posted by Blk02Ls1A4
This is a copy of nhraformula's dyno sheet, before and after the SLP 1.85 rocker arms. This was on an A4.
thanks black, i was looking for that.
btw, thats me.
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
![Buttkick](https://ls1tech.com/forums/images/smilies2/buttkick.gif)
Justanilluzion,why do you say Cranes are a waste.They're one of the best ls1 rockers on the market.Unless your just saying for this guy not to get 1.8's,then you shouldnt just say Cranes.All 1.8's are a waste and I actually own them.And its not that they're even a waste.It all depends on what goals you have for your car.My goals changed overnight.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
