PCV Delete Guys - Problems Running Just Breathers?
Old Sep 22, 2010 | 07:49 PM
  #101
JL ws-6's Avatar
Race your car!
Have you ever tried an evac setup on a car with anything other then open headers?
How did that work?
I already know the answer, but I'm curious what you found.
Old Sep 23, 2010 | 07:36 AM
  #102
Kaltech Tuning's Avatar
Originally Posted by 1slow01Z71
Damn you guys have a reading comprehension problem dont you?
If you got the cash a vacuum pump is your ticket, if you dont breathers work just fine. Simple enough?
Reading comprehension is perfectly fine because what I'm reading is you say vacuum pump is ideal because it'll use vacuum to evacuate crankcase pressure but if they don't have the money then just run breathers and let the rings do all the work. That's 2 different methodsof evacuating crankcase pressure.
I'm posting my point of view on things with facts about how these motors were designed to support my pov. You guys just say we're pushing parts and can't read but put no substance behind your methods other than your internet credibility.
Old Sep 23, 2010 | 11:38 AM
  #103
JL ws-6's Avatar
Race your car!
Car sees no street time. Problem is that Etown, has noise regulations, and open headers aren't an option.
Old Sep 23, 2010 | 02:15 PM
  #104
Bizzles's Avatar
Running dual breathers for two years, no issues yet. wasn't giving GM $70 for a new PCV System when just the grommet broke.
Come run at atco
Old Sep 23, 2010 | 03:06 PM
  #105
JL ws-6's Avatar
Race your car!
Once I get the sled back together, I'm looking to run 8.50 index stuff anywhere I can, if Atco's got it I'll be there, especially if their race days is saturday or sunday, that's alot easier for me to make.
Believe me, I'd love to just leave the exhuast off the car. I have to redo it again I think with oval pipe this time to get it around some of the under car bars that will be there I think... makes for a pita.
Doesn't matter in the long run for this topic as I'm going to put a pump on the car. Probably be the only thing running off the crank pulley other then the external ignition wheel, maybe a dry sump.. if I can come up with the extra 3500
Old May 28, 2011 | 05:15 PM
  #106
s25hanh's Avatar
Originally Posted by BackinBlack02SS
One breather is fine. As stated before, with bay to bay breathing, it is more than enough. Here is what I used for my 02 SS:
Metco breather to replace passenger side oil cap (TR sells them)
plug for drivers side grommet, GM part # 12568011
three 11/32 caps for the passenger side valve cover and throttle body
1 cap (can't remember size) for the intake manifold
anyone have the part number the intake manifold cap yet?
Old Jun 12, 2011 | 05:11 PM
  #107
joseph1's Avatar
hey does anyone have like a write up on exactly what i need to do to make this all work and what i need to buy.. that they might be able to pm me?
Old Jun 13, 2011 | 11:54 AM
  #108
s25hanh's Avatar
yeah that'd be nice. i also got a oil filler cap and filter so i can drill into the into the cap and push in the filter. so i dont have to pay for the 40 dollar metco filter.
Old Jul 15, 2011 | 06:42 PM
  #109
speed_demon24's Avatar
Originally Posted by Kaltech Tuning
This sounds a lot like what a catch can does....
You're posting conflicting concepts. At one point you're saying breathers are fine because the pcv system is crap and then you're saying a vacuum pump is the best. PCV uses vacuum to evacuate pressure so I don't get it. I get that you don't want to hook any system up to your intake to avoid oil getting into the intake but you're making arguements about how and why things work, yet you're contradicting your own arguements about what's better.
Again conflicting statements.
You guys are comparing tearing down purpose built race motors to factory street motors and you can't really do that in this case. Race motors by nature are going to be much cleaner than a street motor because the race motor sees much higher cylinder pressures, heat, etc. than the street motor putting around under 3k rpm and sitting in traffic allowing carbon and everything else to build up. You also need to remember that ls1's are built with small, low tension rings which by design need a pcv system to help them seal better and not get beat up. You want more pressure above the ring than below it because with the low tension rings that pressure above will help them seal, think almost like a diesel. So when you're putting around at low rpm, drawing vacuum you're helping the rings do their jobs and live longer. This is why pcv is important. As far as cutting oil down going into the intake, I have seen quality catch cans significantly cut down or eliminate this. Feel free to look at my website, I don't have catch cans listed there so I'm not sitting here "pushing catch cans" but I AM PUSHING PCV SYSTEMS and running the motor the way the engineers at gm designed it to.
How does the stock pcv system help the rings seal when it doesn't create a vacuum in the crankcase under any conditions?
Old Jul 15, 2011 | 07:04 PM
  #110
ZeeOSix's Avatar
The only time the stock PCV system could possibly cause a slight vacuum in the crankcase is during idle or very low throttle openings ... which causes the highest vacuum level on the manifold, which is sucking on the crankcase. It also depends on how much blow-by is going on under this condition.
Only way to know for sure would be to put a vacuum gauge tap in to the crankcase and test.
Of course, once the throttle is opened up more and more, the crankcase produces more pressure from increased blow-by and the manifold vacuum level drops, so the crankcase pressure then increases.
Old Jul 15, 2011 | 07:08 PM
  #111
JL ws-6's Avatar
Race your car!
The only thing that it really does is evac what could be released into the atmosphere, but instead of doing it into the air it does it into the intake and therefore gunking up the top end of your motor, which is bad no matter how you look at it.
There is some suction/vacuum effect by hooking it up to the intake manifold, but not enough to make the pcv work anywhere near like a vacuum pump will.
I'll vent into the atmosphere all day long and feel good doing that vs putting all that into the intake manifold and into the ports, back side of the intake valves, etc.
I should have taken pictures of the top end of my old 402 after being raced for 2 years, and vented to the atmosphere. The intake ports were spotless, intake was spotless as well. You'd think the engine was just started up a couple times. Had I left a PCV on there, it would have for sure been a mess like eery street car I've ever taken apart for the first time.
As for the ring seal, I 100% agree that a vacuum pump helps this. But, the limited vacuum that a pcv creates, is not enough to make it's bad side effects, worth while.
Old Jul 15, 2011 | 07:12 PM
  #112
JL ws-6's Avatar
Race your car!
This is exactly why a race engine doesn't need a PCV, it's only idling, and essentially seeing a WOT situation. With the WOT being as much or more of the time.. the pressure is forcing the comtaminents out. Hence, why a vented crankcase is a better deal then a pcv on a drag engine... no contaminents being pumped into the intake by the crankcase pressure, dirtying up the air/fuel charge.
I tried the vacuum ga. hooked up to the crankcase on a car once.. at idle, and under 25% throttle it had minimal vacuum... very minimal vacuum. As soon as you put your foot into it at all the ga read pressure. And the vacuum that it did have at low engine speeds, was very limited, no way it was enough to ensure all the contaminents were leaving the crankcase. But, I do guarintee that it was enough to dirty up the intake, as we pulled the intake on that car after about 10K of driving (new intake on the car) and sure enough, it was in the process of becoming a mess.
Old Jul 15, 2011 | 07:22 PM
  #113
ZeeOSix's Avatar
For sure ... in a racing environment where there is mostly WOT, an open crankcase vent system is necessary. Guys that track their cars would be better off if they put an open vent/breather on the valve cover for the time they are at the track.
Old Jul 16, 2011 | 10:53 AM
  #114
got milk??'s Avatar
After 5 years this is still going on wow I remember reading this back in 2006...Read this on PCV then make your own informed decisions.
http://en.wikipedia.org/wiki/Crankca...ilation_system
All I have to say is that if the government didn't require U.S car companies to have a PCV system, do you really think they would go out of their way to have them? If you answer yes to that I will give you my paypal account and you can give me some money too...
Old Jul 16, 2011 | 11:37 AM
  #115
need4fun2469's Avatar
the design is flawed, not the concept. Some of the new cars don't have pcv systems
Old Jul 16, 2011 | 12:38 PM
  #116
ZeeOSix's Avatar
Car manufactures didn't design the PCV system for lots of WOT action, and apparently don't care if the intake system gets flooded with oil or not. So as need4fun said above, most of them are flawed in that respect. People try to prevent oil from contamination the intake system, which is the major result of the design flaw.
Old Jul 16, 2011 | 11:17 PM
  #117
The PCV valve limits the amount of air it lets the intake pull in from the crankcase while the fresh air hose is un-restricted and bigger, therefore there will never be a vacuum in the crankcase with the stock pcv system.
Old Jul 17, 2011 | 12:04 AM
  #118
LS6Vette's Avatar
Glad I found this thread as I had my own little one started.
So is there a vented cap made that is ONE WAY so it vents under pressure but seals up under crankcase vacuum? Leaving the pcv system in place.
Thanks.
Old Jul 17, 2011 | 07:40 AM
  #119
JL ws-6's Avatar
Race your car!
You will never have a crankase vacuum situation unless you put a vacuum pump on the engine. That being said, there is no vented cap that will only allow pressure to be released that I have seen.
Old Jul 17, 2011 | 12:23 PM
  #120
LS6Vette's Avatar
Just when I thought I was understanding this crankcase gas/oil situation. All the other readings/threads/and even an engine builder I exchanged emails with say that at idle & low rpm there is a slight vacuum on the crankcase and as the revs go up to redline that pressure develops.
This is on a STOCK LS6 type motor.
You are clearly saying this is not the case.
Back to square one.
But thanks much for the post.
