should i do the ls6 pcv mod during the H/C swap.
Curious if i should change over the valley cover to the ls6 part for the pvc.Its like 65 bucks in parts to do this,the thing is i already have a AMW catch can on the car and that seems to be working good but when i opent eh throttle body and look in i can still see a bit of oil getting through.Will the ls6 pcv mod help at all??
Lots of people are opting to remove the pcv completely and run 1 or 2 oil breathers. This is a much simpler option and cleans up the engine bay. IMO it is also a much easier option
yeah thats what i am going to do,just get it and be done with it.My car didnt consume a lot before the catch can,after the can its very minimal,so after the ls6 it should be good enough.I dont believe in removing a vacuum assisted ventilation from the crank case,thats just my opinion.thanks viper thats what i was looking for.
https://ls1tech.com/forums/generation-iii-internal-engine/458723-pcv-delete-guys-problems-running-just-breathers.html
Check out this thread here, we have some good info in there as well as some pictures of just breathers.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Might as well do it while you're down there. For ~$60 why not? I just did mine when I swapped intakes. It was cake, even for someone whos never gotten that far into the motor before. I figured if nothing else, that it was good preventative maintenance.
"I dont believe in removing a vacuum assisted ventilation from the crank case,thats just my opinion"
Me either, and after being on this board 5 years I can tell you it's nothing new ( trying breathers ). Not that I'm opposed to learning something new but I'll keep the assistance for a daily driver.
i would like to see an oil analysis of an engine with stock pcv,and the same engine converted to breathers,and see what changed.I bet that a lot more fuel content and other contaminants would be found.If both oil analysis sheets came back the same,then i would change to breathers.Until i see that it doesnt contaminate oil,i just wont do it.
