PCV Valve breather?
http://www.autozone.com/servlet/UiBr...ESPE%7C%7Etrue
and a universal breather filter from AutoZone for $10. Drill a 3/4" hole through the top of the cap and press the breather filter's 3/4" hose into it. The top of the breather is flat and sits about 1 3/4" above the top of the cap allowing the hood to close without hard interferance.
I'm still trying to figure if this will be worthwhile with the PCV system still hooked up, probably not good for street driving, but maybe OK for the track.
I believe the end result of all the two systems is to not build up internal pressure in the crankcase and rocker arm covers. At the track at WOT, there is not much, if any, intake manifold vacuum to pull air out of the crankcase as the pressure there increases. There's no vacuum with a breather filter either, maybe just more flow area to let the crankcase pressure vent better. When the throttle is closed at high RPM, then a high manifold vacuum is created; hence, the need for a check valve (PCV Valve), to limit the amount of air and vapors sucked into the intake. So, maybe the breather will allow more air into the system so the PCV passes more air than oil vapors,
which would condense in the intake manifold? I think it's a fairly straight rule: street cars have PCV systems, while track cars have breathers. So, what's the best setup for a street car occasionaly driven on the track? Hopefully, those with more experience and the knowledge of this matter will chime in: I'd like to learn.
Wouldnt be a good choice because of the breather?
I wouldnt think the vacuum would be strong enough to actually pull in enough air from a small breather like that to effect anything... Any body have experiecne with this can?
That doesn't make any sense......
I understand that the PCV needs to be a closed system with a maf as the air is already metered. Any air drawn from an open breather becomes unmetered. But if you're running SD mafless that isn't an issue.
With a valve cover open air breather and closed PCV.... under normal accel. fresh air is drawn through the crank case through the valve cover breather through the PCV sys and into the intake. Under hard accels where crank case pressure rises... the flow out the open air breather can be reversed and added crankcase ventilation.
I don't see how oil pressure could fluctuate with such a system if there is a source of air from which the PCV sys can draw and not create too much vacuum in the crankcase. Now if you capped off your breathers and just ran a PCV draw, I could see the system pulling oil from the bearings.... And pushing out the dipstick under load.
I beleive what I saw and what I experienced.
Thanks for the comment.
One thing I did notice is when I first put a breather on the drivers side valve cover nipple (normally capped) it didn't vent and pushed up the dip stick. When I put the breather on the passenger side it vented fine under WOT and has worked for many miles. Not sure what your friend did.
Please help me if I need help!
Adrian
What does it take to run a breather in the drivers side cover? I have a 98. Does a 5/8 breather push right into the hole in valve cover or is there a groumet that needs to be installed first then the breather? If so where do you get this groumet and breather? On the pass. side im going to run a metco.
Thanks for any help guys.
