TSP Magic Stick 3: Daily driver?
Second, you'll need a stall converter first, otherwise drivability will be non existant. Look at something like a 3500-3800 stall first...you'll be amazed at the difference. You may even get more performance from a stall over a cam...low 12s shouuld be no problem with a good stall and bolt ons.
When you get around to getting the MS3, expect less than 400 rwhp. It will pull like crazy, but it wont be a dyno queen...autos dont dyno like manuals, but they tend to perfrom much better at the track. You will need a tune for sure and valvesprings that will handle atleast .625" lift...PRC or Comps will do. Look into a double roller timing chain, pushrods, and maybe an LS6 stock replacement oil pump sionce you have a 98.
You'll have around $800 into parts alone to swap the cam. For that, get a good stall first.
I'm expecting over 390 when I switch to an MS3 or T-rex, maybe even 400.
