Thermostat, Which one to use?
I am confused about the thermostat people are using in the LS1. The aftermarket has a 160* and a 180*, where the factor has a ~195*. I have been told that the engine was designed to run with the 195*. The 160* will cause the engine to run richer due to a cooler ECT. What is the best for the engine? Performance?
True, I have stock thermostat and it opens at about 184*( put in hot water and measured with thermometer) and I have the fans programmed to come on at 178. The fans help so much on hot days.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by ls1charged
yeah your in NJ right, im in FL it gets alil toasty down here. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
yeah i agree, i just like to make sure that it doesnt get to warm, i know its not supposed to get to cool cause it run efficiently, but it also doesnt run as efficient when it gets too hot, i basically put a 160* in cause i live in florida where its 95+ all summer long and its a black car, worse combination.
The color of the car doesnt matter, but I have to 160 hypertech in mine. That particular one doesnt open right at 160....... I run a constant 170-175. I live in Texas so I am happy with that any day!
Originally Posted by squealingtires
what is normal operating temperature. My guage in the dash shows 210* when warm.
Guys, perhaps some of you are confusing thermostat opening temp and actual running temp.
A 160* stat just allows coolant to flow through the motor at 160* that is all. I doesn't mean that the car will run 160.
