View Poll Results: Which cam will produce a better ET?
T-Rex will drag an MS3 car down the quarter mile
322
66.53%
MS3 will drag a t-rex car down the quarter mile
162
33.47%
Voters: 484. You may not vote on this poll
T-REX vs. MS3 on the track.
Old Dec 13, 2007 | 10:08 AM
  #141
import slayer's Avatar
Originally Posted by 2nasty
isnt the t-rex a little big for a stock motor?
No it's not.
Old Dec 13, 2007 | 10:29 AM
  #142
Jay2002ss's Avatar
Default T-rex
After installing 3 different cams in 3 different cars. The out come is this.
The F-14 in a 98 TA with all mods shows 395 RWHP
The MS3 in a 99 TA with all mods show 398 RWHP
The T-REX in a 02 SS with all mods show 432 RWHP
All cars had factory heads, pistons and all common bolt ons.
All Mods on the cars was headers, intake, lids, true dual X pipes and of course the package of dual valve springs, locks and retainers and push rods.
The only different was the ss had underdrive pulleys. These are the cars I have done and seen first hand on the Dyno's. Just remember the T-REX is a race cam and the only down fail I have seen with that cam is Plugs and maybe a annually tunning..
Old Dec 14, 2007 | 07:11 AM
  #143
LS1-NAVY's Avatar
i think the t-rex would be better
Old Dec 17, 2007 | 12:51 PM
  #144
BlackScreaminMachine's Avatar
Internet Mechanic
Originally Posted by prostock_bigblock
For me its unfair comparision since every car is different , there must be some good factors so we can make this fair , and some of those factors are gearing , weight , tuning , driver , stick or auto .... etc .
I would probably compare the 2 cars if they were build equally , and when I mean equally , cam only plus the factors that i listed above.
^Agreed
I know there is prob alot of remarks about this but that when you look at the fastest cam on cars, ALOT of it has to do with the raceweight, the heaviest car weighing in w/ driver 3500, but the majortity is about 400-700 pounds lighter. Thats makes a HUGE diff when you start comparing times and mph's.
Also the heaviest car of the bunch runs a 4.5X rear gear to get that porker out of the hole quicker.
You really needed the same car, and similar weather to truely determine what works best for that car, odd are though T-rex should beat the MS3.
Old Dec 11, 2008 | 12:51 AM
  #145
BIGB4015's Avatar
I think it dependes on weight the ms3 could be quicker in some cases. In a car with equal weight,suspention and gears I would have to give it to the Trex.
Old Dec 11, 2008 | 10:41 AM
  #146
pitbull14218's Avatar
The heads differ from certain years, heck even my buddy with a 2000 T/A has different stock heads then my 2000 WS6 because mine was made a month newer then his. i have 241's he has something like 809's or something.
Old Dec 11, 2008 | 07:35 PM
  #147
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Haha, holy old thread. I find it amusing when people start throwing in new cams like the vindicator and MS4. When this thread was created 2 years and 8 months ago those cams didn't even exist. I think that shows how well the Trex really works. Even after a few years people are comparing new cams to it. I recently bought a short block with a T-Rex in it. I plan on sticking it in my 93. It should be fun in a 2900lb race weight car.
If you still want to argue Patrick G covered it in the first page:
Originally Posted by Patrick G
Actually, you have to rev the MS3 higher than the T-Rex to make best ET. The reason why is that the T-Rex has better dynamic compression and builds better power under the curve. The mid-range torque is superior because of the narrower LSA and its top-end speaks for itself. The MS3 is a revver. The T-Rex is a monster.
Just look at the cam-only ET records and see what cams dominate the top. Either T-Rex's or T-Rex clones (like LS1 Joe's).
Old Dec 12, 2008 | 03:10 PM
  #148
LS1BLKSS's Avatar
Banned Village Idiot
damn ms3
Old Dec 12, 2008 | 06:37 PM
  #149
Geoff's Avatar
I am the one who designed the T-Rex. Actually with some of the latest design process I am doing now, I just did a cam that will step on either of them pretty bad...It has a wider power band, and revs higher. Details to come...
Old Dec 12, 2008 | 06:42 PM
  #150
krazy4's Avatar
T-REX hands down!
Old Dec 12, 2008 | 08:56 PM
  #151
OWN3D BY MY PROF!
You have me excited. I'm looking forward to something like that since I realized the cam in my engine I bought isn't a T-Rex.
Old Dec 12, 2008 | 09:58 PM
  #152
Orangepeeler's Avatar
Geoff, I am very interested in the cam you are designing now. I am planning to do some Drag Radial stuff next year and would like to step up from my MS3. Thanks, mike.
Old Dec 13, 2008 | 08:49 AM
  #153
Geoff's Avatar
It will be available after January 1st. As an FYI I just tested a cam only combination (stock 241 castings, LS6 Intake, 75mm throttle body, 75 mm MAF) against a combination that had a set of ported LS6 Heads and a cam larger than one of the one's listed in this thread from one of the more popular vendors around here, a FAST 90, 90 mm throttle body, and a 85 mm MAF.
My cam only deal made more low end torque, the same peak power, and actually carried higher in the RPM band. We shut the pull off at 7200 RPM because this was a stock short block! This thing was still pulling...
Old Dec 13, 2008 | 09:02 AM
  #154
98blueSScamaro's Avatar
very nice
Old Dec 13, 2008 | 09:10 AM
  #155
Chhh Chhh's Avatar
trex is a ****** monster all around just ask me how i know
Old Dec 13, 2008 | 05:21 PM
  #156
5_02ls1's Avatar
will this new monster cam clear without flycutting and will it be a n2o friendly cam????/very interested....
Old Dec 13, 2008 | 05:29 PM
  #157
x2. Also, will it work as well with carbed applications?
Old Dec 13, 2008 | 05:30 PM
  #158
w3s1c0a5t's Avatar
Dont tease me.... Lets here some more about it. Pm or make a new thread if need be. Very interested in what you have to say.
Old Dec 13, 2008 | 06:59 PM
  #159
Geoff's Avatar
Things have changed with me. It will be more clear in the next week what I am talking about...
As far as the cam is concerned: P/V will be VERY tight. Either flycutting or sinking the valves in the heads (or aftermarket heads with better valve drop) would be a good idea. Honestly, the P/V will be similar to a T-Rex, but it should definitely be checked in any case.
This cam will make similar peak numbers to a T-Rex or MS4, but the power will start 700 to 1000 RPM sooner and carry MUCH further. It also will be VERY happy with spray. In fact the only issue with using this cam with spray will be getting the car to hook. This cam will hit VERY hard off the line.
I will start selling this cam Jan. 1st.
Old Dec 13, 2008 | 07:04 PM
  #160
Geoff's Avatar
It has been optimized for a long runner intake.
The cams I am doing for single plane applications are different. I have a couple of cams for this type of application, but keep in mind that if you use any of the 'popular' off the shelf cams in a carb application it won't be optimal. A cam for a single plane intake, by necessity needs to be very different than what is done for a long runner intake.
