650+ lift. what springs r u using?
As of now i have the Trex in my 408, runs great and pulls hard all around. With my cubes i know i have more room to grow, but couldnt find a valve spring with over a 650 lift. I am using the pat-golds that are rated at 650, but is there any other springs out there that i can use without michining the heads to make them fit? My plan is to run somewhere around 660's in lift. Thanks for the help,
chirs
chirs
Texas Speed and Performance. They are about the same price as the patriots. That kit is showing .660" lift, however, I'm sure you can specify the platinums and get the .670" lift. They are $289.99 a set, click link for more details.
does look good, wondering if i could reuse my retainers from the golds and just buy the springs alone? So i am guessing this is the biggest spring you can buy without the machine work?
thanks for the replies
chirs
chirs
Originally Posted by SVT THIS
Can OEM replacement lifters be used in a TRex application? Or would it be wiser to go with a comp r lifter, or lunatic or morel? I'd rather not spend a fortune on lifters if it is not absolutely necessary.
Originally Posted by Hennytime
would those platinums work well with the new lsk lobes?
Justin
Originally Posted by SUX2BU
I believe the PRC's and Patriot golds are the same spring.
