Free drop on Dart 225s v. Stock LS1 Heads
Patrick G and I are working on a Heads/Cam selection for my new project. I want strong power up to 7k RPM with good Dynamic Compression. I'm currently planning on getting Dart 225s and using a .040" gasket and getting Patrick's recommended cam, 232/236 .644/.646 110LSA +1. He wasn't sure about PTV clearance with regard to free drop on the Dart 225s. Someone here (esp one of the Dart guys) must know if the free drop is the same, better, or worse than stock so I can confirm PTV clearances.
Thanks.
P.S. Please don't just tell me to measure. I'm not going to flycut, so I don't want to get everything I need only to find out it won't work.
Thanks.
Well my 1.8's wont fit under the 205's with the sdpc 220/224 cam. Only around 0.020 clearance. Seems due to larger 2.02 valve. So Im having to run 1.7's. (Must change my sig!)
Id have thought it would be fine. Thats with stock MLS gasket too. 0.006 duration is 282/286
Holey cow? Did you measure? I am running the next one down (216/224 0.551/0.551 115 LSA) and thought I might go back to my 1.8 rockers, maybe I can't. I knew I should have measured the PV while it was apart
Yep the shop measured with plastercine and called to say it was too tight. Cam has 56 deg overlap at 0.006. I saw you were using the 1.7's (Same crane/vinci/sdpc cam as you say but next one up..) The guy doublechecked cam timing, thats dot to dot with 4 deg advance ground in. So with stock 1.7's will be around 0.060 or so clearance .
Yeah assuming the shop dude set the cam timing up right, and I have no doubt he has, then I think you will certainly want to check clearance first. Exhaust was ok btw.
Originally Posted by Jason99T/A
Free drop:
Dart 225s: Intake: 0.140" , Exhaust: 0.172"
LS1 241 castings: Intake: 0.165" , Exhaust: 0.175"
Jason
Jason
sorry to say it but not going to fit, i had to cut my pistons, and i'm running slghtly smaller then the cam your looking at.
I was at .060 on the intake which is a little to tight, with your cam your prolly goin tto be in teh .040 area.
But honestly i just cut my pistons today for the first time, and its not hard at all, took me no longer then an hour and half.
Justin
Justin
