Cylinder wall scratched
Well before I was putting on my final cylinder head today I noticed that 2 of the 4 cylinder walls on the drivers side had a couple very small scratches in them. They were typically about an inch long and running vertical.
They were deep enough so that you could just barely detect them with your fingernail. I couldnt hook my nail on them...but could just barely feel them.
The only thing I can think of is that when I rotated my crank to clean off the pistons something could have gotten in between the cylinder and the rings and caused this. as I didnt clean my cylinders completely until right before I put the heads on...so I guess this is possible. But it was spun very slowly only a couple times...I am confused.
The car ran fine before and used no oil.
Should I be worried?
thanks a lot
thanks a lot
leak down test was ok...do you guys think it will be alright?
anyone else have some input?
Is it possible this could cause problems in the future? like my rings going bad in the next few thousand miles?
Does anyone know any good products that can cover up minor scratches in a cylinder wall? do any engine treatments claim to do this? im not sure
my top end is all new...so I dont really want any product that is supposed to freshen up valve seals either...unless this wouldnt hurt on a new head.
thanks again
thanks again
Engine treatments claim to but they are typically ineffective as advertised. If the scratches are not to deep and leak down was good I say run it till she blows. You shouldn't have any issues, Engine restore is sold at any Wal-Mart, or Auto Parts store so pour it in with the oil and it may or may not work. But what it will do is give you peace of mind. Pull the head in a few weeks and give the cylinder walls a look.
Like I said they are very light. I could feel them with my figernail just barely...but could not hook my nail on them.
I think ill put a little bit of the engine restore in...unless anyone thinks this is a bad idea???
Im just worried about the future...I want this thing to last a while.
I would think twice before putting any additives in the oil.
Most engines have slight imperfections in the cross hatch from the thrust side of the piston. Sometimes a very small partical gets between the ring and the wall and causes a mark. Or it may have happened the first time the engine was ever turned over.
Like they said above if you have good leak and compression numbers don't worry.
Good Luck
Ryan
Good Luck
Ryan
that sounds like just what it could be... the cylinders still look perfect besides those marks, they still show crosshatching very clearly at 91k.
is the thrust side of the piston the side that is facing the fenders on each side of the block? If so then I think you are right...because the opposite of the "thrust side" and everywhere else in the cylinders were flawless.
thanks again
thanks again
thanks again
thanks again
