changed plugs all but 6 & 8
I changed all my plugs but number 6&8 plugs I cant get to them. I tried for an hour and still couldnt get the them. Any one know easy way to get to them?
Also what else should I do to tune the car up the easy way. I changed plugs and wires what else can I do?
Thanks
Mario G.
Thanks
Mario G.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
regarding your tune-up, i would've seafoamed it, top end & gas tank...then changed plugs/wires and fuel filter, air filter..maybe autorx'd the oil and changed it, as well. just depends on how far you want to go.
Remove your coil pack, makes a world of difference. I use a good 1/4 drive ratchet and swivel, with a 1/4-3/8 adpt. to spark plug socket, works great.
Back bolt is a tough one to get out on the coil pack. Some leave it out I slotted the hole on the bracket, reinstalled the bolt at a a good height to where I can slide the back of the bracket back in. Then install the rest of the bolts.
Originally Posted by Duffster
Do #8 from underneath. . .
wow it took to the 6th person to get to the point.... 8 get an ext. and get at it from underneath, hmm number 6 u might need a different ext. havent heard many people struggle with that, but its a pain for me to
Originally Posted by s346k
i removed the back coil bolt and threw that mfer as far as i could..
i just hope the neighbor doesn't hit it with his mower or something.
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
Now to the issue. #8 for me is easiest from the bottom (M6). On my fiancees car I have to get it from the top because the tranny lines are in the way(A4). #6 I haven't found to be much problem.
You just need to find the right combination of ratchet, extension, swivel, socket to get it done. I found that using a reducer like a 3/8" drive to 1/4" drive will sometimes give me the right length to reach the plug and still be able to ratchet.
Pulling the coil packs and air tube (If you haven't already) will make your life a whole lot easier.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
i got to #8 from the top. i removed the coil packs, and the air tubes. it took me about 30 minutes just to figure out what combo to use with it. i used the spark plug extension combined with 1 extension about the size of your pinky finger and the one half that size. also, get the extention on the spark plug BEFORE you attach it to the wrench. this is key. and once you get it on (take sa couple minutes to angle it right) you'll only be able to turn it about 3-5 clicks (1-3 clicks each way) and i couldnt get the breaker bar in there, so you'll really have to muscle it. o and def use mech gloves in there, something cut me pretty good when i was trying to muscle the last plug off, and i broke it too, but thats something else. good luck
wait just htinking about it the #8 is on the pass side right? b/c i didnt remove anything from the driver side and i have huge hands...im 6-5
