Do you have to remove the waterpump to...
In theory no, in reality, yes.
Needs to come off to get the power steering pump off unless you pull the pulley.
Other then that I cant think of any reason why it would have to come off?
On the LS6 you can leave the water pump and pulley installed on the bracket. I backed out the bracket, and removed the resevoir to access the rest of the bolts. I modified the resevoir bracket, so next time it will be much easier and faster. Speaking of the shop vac. I made a hose fitting using a drinking straw, gets the coolant and oil out of the head bolt holes in seconds.
All you have to worry about is chasing the threads.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
