Stock LS6 heads with TSP Cam...what pushrods?
I have stock LS6 heads and gaskets and I want to put a TSP 224/224, .566"/.566" 114LSA tsp cam. I talked to Zack at TSP and he says the 7.4" manley hardened pushrods I already have are ok to use. Sounds like the 7.375"s are a better bet according to PREDATOR-Z . My question is what kind of problem if any will I run into using the 7.4"s?
Originally Posted by PREDATOR-Z
If you are doing:
LS6 heads/valves + LS6 cam > stock or 7.40 aftermarket
LS6 heads/valves + Ls1 cam > 7.375 aftermarket
LS1 heads/valves + LS6 cam > 7.425 aftermarket
7.40s are fine. You should use 7.425 for either the LS1 or LS6 head and LS6 cam. Assuming unmilled with stock gaskets. FWIW, tsp 231/237, LS1 heads milled .030 and 7.40 pushrods here, no problems.
Brandon
Brandon
Good to know pitbull. I'll try the 7.4"s then
Had searched this topic alot and just now finally found this thread:
https://ls1tech.com/forums/showthrea...ht=base+circle
Originally Posted by orangeapeel
He likes a quieter valvetrain.
From what I can gather, the base circle on the on the LS6 camshaft is smaller and the valves are are longer to compensate for this smaller base circle. The stock LS6 pushrods are 7.4" just like any LS1 but that means if I'm using a camshaft with the larger LS1 base circle with the longer valves then what PREDETOR-Z is saying sounds right, I may need somewhat smaller pushrods. I guess I was just curious as to whether having pushrods that are maybe ~.025 too long or so is going to cause any problems or if this will cause too much stress on the lifters or valvetrain geometry .
Originally Posted by flyin ryan
What about an LS1 with a stock LS1 Cam,
stock Z06 heads,only a slight valve job no milling, and GM graphite gaskets. Can I still use the stock Ls1 push rods ?
Thanks Ryan
Thanks Ryan
Originally Posted by cantdrv65
Again depends what year Z06 heads....
Flyin Ryan, depending on the amount you mill, it would probably be perfect to use the stock 7.4" pushrods. The milling might take up the slack the longer valves create(if again you have the 02-04 Z06 heads).
I don't plan on milling mine so I want to make sure I don't cause problems.
Milling will require a slighter SHORTER pushrod not longer.... It sounds like you have an XE cam I have no idea how the basecircle of that cam compares to the stock 02 LS6. Compare those two basecircles and then simply add or subtract from the stock pushrod length. Im betting the 7.375s would be damn close.
DOH sorry bout that
Yeah sounds right...I think I'm just going to try the 7.4"s. I think the worst it will do is be hard on the lifters. (Crosses fingers)
