ARP rod bolt torque spec
Old May 25, 2006 | 11:31 AM
Boostaholic's Avatar
Default ARP rod bolt torque spec
What are you suppoesd to torque ARP rod bolts to?
Old May 25, 2006 | 03:31 PM
TAF Motorsports's Avatar
For the 234-6301 rod bolts
using the ARP Moly lube,
Torque to 40lbs
loosen
Torque to 40lbs
loosen
Torque to 40lbs third and final time
Old Aug 29, 2006 | 09:28 PM
dirt track racer 81's Avatar
sorry for reposting to an old thread..i just ordered my arp rod bolts, do they come with the moly lube.. i know my head bolts did not, can i just use 30w oil?
Old Aug 29, 2006 | 11:17 PM
anyone??
Old Aug 30, 2006 | 08:57 AM
Gearhead1's Avatar
You can, but the torque specs change because of the different lubricating properties of the 30 weight. Go spend $7 and get the right stuff from ARP.
Old Aug 30, 2006 | 01:46 PM
JOHN LAWSON's Avatar
The spec. on arp rod bolts, is to stretch the bolts .0045" - .005" with molly lube.
You will need a stretch guage to check this.
Old Aug 30, 2006 | 02:15 PM
thunder550's Avatar
High on diesel fumes
My ARP rod bolts came with the moly lube.
Old Aug 30, 2006 | 02:19 PM
1BAD02WS6's Avatar
mine didnt come with lube either and the instructions told me 45lbs 3 times???
Old Aug 30, 2006 | 03:26 PM
GuitsBoy's Avatar
Different torque specs for moly lube vs engine oil.
Old Aug 30, 2006 | 05:27 PM
LS1-IROC's Avatar
Get a rod bolt stretch gauge and know it's done right. The last motor I put together I went through and checked stretch versus torque readings and they varied by almost 7 ft/lbs.
Old Sep 4, 2006 | 08:37 PM
northcoastrides's Avatar
I am putting a 5.3 in a S10 while the motor is still on the stand should I be swapping out my rod bolts for ARP's and if so how much of a nightmare is it to do with the motor still assembled?
Old Sep 4, 2006 | 11:39 PM
DuronClocker's Avatar
Hmmm I'm pretty sure I went 55ft-lbs three times on each bolt when I did the bearings/bolts in my bottom end. I'm pretty sure that was with their moly lube.
I'll have to go back and think it over for sure, but I *thought* that's what I did.
I bought the non-waveloc bolts, it was like the $70 kit instead of the $80 or $90 kit.
