Valvetrain chatter @ ~2500rpm with cam?
Just wondering if this is normal. Have a FM14 (232/234 .598/.598 112 LSA) and Patriot Gold Dual springs. At ~2500rpm when cruising I get a lot of chatter from what sounds like the valves. I am not 100% sure that's what the noise is, I'm an engine newb, but I don't know what else it could be.
Edit: It's not really that annoying, and I've driven a few thousand miles with it like this, just curious.
Thanks for any advice guys
Originally Posted by bigman
Pushrod lenght may be playing a big part in this.
It might be that your lifters haven't fully pumped up yet. When I did my head and cam swap (2 different times) I had the same thing for a long time and eventually it went away.
I just recently finished a g5x3 cam, headers and 90/90 setup and mine does the same thing when hot. When it`s cold no noise, so it makes me think it could possibly be the type of oil i`m using for right now mobil 5w30 I found a bunch of 5w40 that i`m switching to this weekend, by the way I have about 800 miles on mine and it`s been doing it since the swap. I also think some of the noise is coming from the injectors, lucas #42`s.
235/237 futral cam here with patriot golds. nice and noisy while cruising and for a split second when you let off the throttle after a given cruising speed.
3K miles on the setup, no issues as of yet. and i been spinning it 7K constantly.
