59cc Dart heads, 90/90, G5X3 cam install is complete.
Well, I am happy to say, after working on the car for a month when time allows, the car is finished. This is my 1st time ever doing anything like this and after doing it all myself (for the most part) it all came together. I did have some smoking at first but then discovered I did not have my oil dipstick tube in causeing some oil to blow out..
Specs on the new stuff:
Dart 205's milled down to 59cc
.040" Cometic Gaskets (yes, I notched the pistons)
90/90 set up
G5X3 Cam on a 114
New Oil pump, Timing Chain, Pushrods, Lifters, 36# injectors, Z06 MAF, etc
Under drive pulley.
And everything else in my sig.
Im getting the car Dyno tuned on Thursday.. Hoping for some good numbers.
Wanted to thank TSP for putting up with my calls every other day and Bobby over at LGM for answering questions for me, LS1Tech for answering my questions too. And my bud Gino that helped me out as well..
Here is the vid. from under the hood.
http://video.ls1tech.com/video/857fb...5b8550f117.htm
Here is an idle vid. ~1000 RPM
http://video.ls1tech.com/video/0e7d6...7f18d30069.htm
All untuned as I just played around with the idle screw.
90/90 set up
G5X3 Cam on a 114
Under drive pulley.
I can't wait to see these #'s
For the little bit I got to drive my car with the cam before the motor puked I was in love with the X3 cam. It idled great at 800 RPM and the pull up top was insane for a cam only setup.
Originally Posted by vettenuts
What lift on the cam? Did you stay with the Dart valves/springs?
Sounds nice, can't wait to see the numbers on it
I too have a similar set up... on an A4 none the less.... It is refreshing to see some healthy A4's for a change... I always hate hearing the typical "Why not an M6"?
I am running an RPM4 cam 232/236 .595 .601, Yank SY3500,pulley,long tubes,true duals "out the rear",LS6 intake,28.8 injectors( mines a 2000, had the 26's)
Ported TB, my car dynoed @ 388rwhp dumped.. 377ran out the back.. My LS6"S 243's will be done by the end of the week.. I am having a local guy CNC, port/polish & trick them out a little.. I'll post pic's and numbers once installed... Congrats on your set up.. Sounds great!!
Originally Posted by waterbug1999
What happened?
90/90 set up
G5X3 Cam on a 114
Under drive pulley.
90/90 set up
G5X3 Cam on a 114
Under drive pulley.
