Ms4
Old Jun 4, 2006 | 09:38 AM
  #41
Zach@Texas-Speed's Avatar
Originally Posted by jinxedz
put a 'everything id need for a cam swap' package together and you have a customer ...
MS4 camshaft, PRC Dual Valve Spring Kit w/ Titanium Retainers, Hardened Pushrods = 689.99.
Complete Cam Install Kit which includes all necessary GM bolts/gaskets for installation = 43.99
Throw some shipping in there and depending on if you need oil pump/timing set that is the total cost you would be looking at minus oil/coolant.
Let me know if you have any more questions!!
Zach
Old Jun 4, 2006 | 11:11 AM
  #42
mousetom78's Avatar
As much respect I have for TSP and its products. But this logo sounds little too rice. 82 fly wheel HP? You should just do rwhp before and after on a stock cam with full boltons vs a tuned MS4 cam. Post little more under the curve power vs peak power.
Remember all honda civic with turbo makes 500 fwhp and run 13's.
Old Jun 4, 2006 | 11:19 AM
  #43
viper2fast's Avatar
can i run this cam with my stock engine i meen stock pistoins and stock heads
Old Jun 4, 2006 | 11:29 AM
  #44
weaponZ's Avatar
im also interested in dyno numbers(before and after cam),track times(before and after)and any other peice of info to convince me to upgrade to this cam.
Old Jun 4, 2006 | 11:40 AM
  #45
a98ws6's Avatar
Zach
How about if this cam is based towards stock heads/pistons or HC setups???
Old Jun 4, 2006 | 02:22 PM
  #46
Superjoe's Avatar
This cam sounds like the perfect stop gap for my stock '00 LS1 until I get the money for the low compression (read: blower) 402 this winter. My question is, would this be a fitting cam for a larger cube/SC'd motor later on? I'm guessing no, and that's not a big deal but it would be sweet if it was!
Old Jun 4, 2006 | 03:21 PM
  #47
StrokerLS1's Avatar
tsp just got a new customer
Old Jun 4, 2006 | 09:00 PM
  #48
s346k's Avatar
so basically the "new" ms4 is...an ms3 with slightly more intake duration on a slightly tighter lobe separation?
i am disappointed. i was hoping to see a cam comparable to the t-rex with some kind of implementation of the more aggressive (lsk) lobe designs.
Old Jun 4, 2006 | 09:08 PM
  #49
Believe it or not, but 82fwhp is what the gains were on an engine dyno. This was a before and after test from a stock cam to the MS4.
We have been doing rwhp numbers as well, but by doing an engine dyno it weeds out all the little variables that come into play.....it shows the true power being made over a stock cam when you can swap cams in 30 minutes and see the gained power. What is more true than that??
Also, Like Jason posted earlier our last test car gained 72 rear wheel horsepower with the MS4 & underdrive pulley
Old Jun 4, 2006 | 09:10 PM
  #50
You would want to go with something larger for a larger motor, you would be leaving power on the table using this cam in a 402ci motor or similar.
This cam will work with stock heads
Old Jun 4, 2006 | 09:12 PM
  #51
This cam picked up huge numbers coming from a stock cam and using the stock heads. So this cam does work great with stock heads/pistons and the same can be said for a HC setup.
Zach
Old Jun 4, 2006 | 09:14 PM
  #52
Yes!
Old Jun 4, 2006 | 09:29 PM
  #53
REDWS6ROCKET's Avatar
zach, any numbers with prc stage 1 ls6 heads and the ms4 yet. i would think that it that combo would put down some stout numbers!
Old Jun 4, 2006 | 10:33 PM
  #54
Ted J's Avatar
I'm curious, what other mods did that car have?
Old Jun 4, 2006 | 10:51 PM
  #55
Chris Gage's Avatar
This is what I am waiting for..... I know alot of budget builder will eat up this combo if everything clears right and depending on the streetability with this cam....
I am very interested in seeing numbers for this combo: Pacesetter headers, PRC stage 1 LS6 heads with stock valves (non-comp job), MS4 cam, LS1 intake.
By showing number for this combo, poeple with better intakes know they should see more power... Also, as I stated before, the budget builders will love this combo.
Seems like TSP has been hard at work lately, they came out with a great head, then they made it better, now a cam that looks like it will dominate on the streets. Cant wait to see some numbers and see what they come out with next
Old Jun 4, 2006 | 11:11 PM
  #56
RoastEmSS's Avatar
im tempted to send back the torquer for this beast
Old Jun 4, 2006 | 11:13 PM
  #57
ritefulback's Avatar
ditto
Old Jun 4, 2006 | 11:14 PM
  #58
i woudn't just keep your set up, i see how good stangkilr's runs with an auto. your car is going to scream
Old Jun 4, 2006 | 11:33 PM
  #59
RoastEmSS's Avatar
it screams if it can shift past 1st gear i hear hes been having some bad tranny luck
Old Jun 5, 2006 | 12:17 AM
  #60
OOZ28's Avatar
Does anybody know the lift on this cam yet??
