Right Heads!!!!!!!!!!!!!!!!!!!!!
Old Jun 14, 2006 | 06:09 PM
Phoenix 2001's Avatar
Default Right Heads!!!!!!!!!!!!!!!!!!!!!
Hey guys, I need some help. What set of heads would flow well with the SLP 402 Iron Block with high comp other than AFR'S????
Old Jun 14, 2006 | 06:59 PM
Wnts2Go10O's Avatar
l92s maybe. ud just need to find an intake..
Wnts2Go10O's Avatar
ps...i hope you hve better luck than a few ppl here witht the zl402
Old Jun 14, 2006 | 09:30 PM
Okay, what's the deal with the motor???
Old Jun 15, 2006 | 09:33 AM
GuitsBoy's Avatar
If you dont want the AFR's, then ETPs are probably out of teh question too. You could get some Dart 225 heads for a bit less. PRC has a new stage 3 dart package.
Old Jun 15, 2006 | 12:43 PM
The only reason I didn't want the afr's is because i think there a bit to much, but open to other options.
Old Jun 15, 2006 | 12:44 PM
I'm going to look at the etp's right now, thanks bro.
Old Jun 15, 2006 | 12:49 PM
Wnts2Go10O's Avatar
a few ppl here hve had their motor literally fall apart when they started it
Old Jun 15, 2006 | 01:44 PM
Really, what reason could they give???
Old Jun 15, 2006 | 01:51 PM
jrp's Avatar
jrp
SN95 Director
define "a bit to much". if you think the AFR's are a 'bit to much' then forget the ETP's.
you just spent over 4k grand on shortblock, dont cheap out now on one, if not, the most important parts that will effect your power.
Old Jun 15, 2006 | 01:59 PM
66deuce's Avatar
i agree.i tried going the cheap route,and it cost me more in the long run.i've spent more money getting my heads right than what a new pair of AFRs would cost.
Old Jun 15, 2006 | 03:09 PM
Mike@TEA's Avatar
Trick Flow or Dart??
