Clearance Issues w/ ETP 245s
I have a FFHP iron 408 built to the following specs:
FFHP 408 iron block
11.34cr
Eagle 4" crank
-2cc Diamond pistons
Callies Compstar rods
AFR 225 72cc heads w/ PRC .650 duals (not milled)
247/252 .646/.644 113+0
SCE Titan ICS head gaskets .043 in.
Comp pushrods
My new intake (Harrop Hurricane out of Australia) is outflowing the AFRs and I want more power. My thoughts were to go with the ETP 245s with 72ccs. I talked to Thunder Racing who I bought them from and they said I shouldn't have issues with valve clearance (but it will be close) and I talked to FFHP and they said I will most likely have major issues. Does anyone have this setup or have experience with it. I don't want to bolt up the ETPs to find out that they won't work because then I can't return them per the Thunder Racing return policy. Thank you in advance guys.
Matt
FFHP 408 iron block
11.34cr
Eagle 4" crank
Comp pushrods
Matt
With the 72 cc heads you should not even be close. I would have to know the cam events to dictate that for sure though. Most of our big chmber heads have worked without any valve notches.
