this is the fourth crank sensor!!!!!!!!!
Old Jun 21, 2006 | 07:52 PM
DaBigJC's Avatar
Default this is the fourth crank sensor!!!!!!!!!
any1 ever have this problem?
any1 know what possibly causes it to go bad?
i am on the fourth 1 for my car and it only has 30k on it.
the latest was frikn hours old.
i installed it, went for a test drive, then later went for a cruz. no real hard driven. then mid way through it bit the dust.
car bogged, backfired, then stalled out, and ses came on. then repeded same all the way home.
if it is a mod i have on my car dear god i will take it off. please help me
Old Jun 21, 2006 | 07:57 PM
mrr23's Avatar
do you have headers? there is a loom of wires going down the passenger fenderwell to the starter. that wire looms houses the some of the starter wires, passenger rear o2 wires and crank sensor wires. i thought i had a bad cat on the wife's car because i was getting a P0430. then it started running weird. backfiring, stalling, so forth. went to replace the crank sensor after i finally got the crank sensor code. that's when i found the wires melted to the headers. i lengthened the wires and rerouted them away from the header.
Old Jun 21, 2006 | 08:22 PM
under pressure's Avatar
I think mrr23 has a good point. If the sensor is not physically damaged, the wiring and connector would be suspect. You can test the wiring for continuity. Also, your vehicle pinout can show you the destination of these wires. A hall effect sensor should have a 12 volt source, ground, and signal wire to the PCM. Let us know what turns up.
Old Jun 21, 2006 | 08:24 PM
DaBigJC's Avatar
so by that aspect the sensors r still good it's my wires?
Old Jun 22, 2006 | 02:12 PM
DaBigJC's Avatar
well i have been playn with it for the day.
from looks the wires dont apear to be damaged.
ther r touching the header in a spot but the loom is wraped in that shiny heat tinfoil stuff.
i swaped sensors. back to the first 1, the car ran for like 2 min then died.
i am sending it to east side to have them rip the pass side header off and get a good look at whats up.
maybe leanthen the wires maybe some header wrap.
hopefully it will fix the problem.
any other tips are welcome
Old Jun 22, 2006 | 02:16 PM
JL ws-6's Avatar
Race your car!
No help for you, but keep us posted as to what you find.
Old Jun 22, 2006 | 02:23 PM
bigredexpress99's Avatar
could be the releluctor wheel on the crank?
Old Jun 22, 2006 | 02:50 PM
TorchRedZ's Avatar
A buddy of mine had the same problem, after buying a couple of sensors he took the car in only to find out the whole time that it was his battery that was going dead.
Old Jun 22, 2006 | 09:03 PM
SLowETz's Avatar
Have the code scanned first.... have you done a CP relearn?
Old Jun 23, 2006 | 05:23 AM
Nate_Taufer's Avatar
I would think your reluctor wheel is walking around on your crank.
Nate
Old Jun 23, 2006 | 06:50 AM
PonchoFan's Avatar
I had one go after a cam install. Car backfired like a ****.
Old Jun 23, 2006 | 07:03 AM
JL ws-6's Avatar
Race your car!
Have you had your motor built?
Old Jun 23, 2006 | 03:59 PM
Boostaholic's Avatar
Sounds like your wheel is loose, wobbling around or something - on some forced inductions cars have the wheels welded to the crank in a few spots to keep them still.
Old Dec 21, 2006 | 09:11 PM
Z28FirefighterI1's Avatar
Just had that same problem pulled the motor out and found that the crank was walking. Looked like something was pushing on the on the back of the crank. The thrust bearing and the crank got ate up. Hope you had better luck than I did.
https://ls1tech.com/forums/generation-iii-internal-engine/627424-crank-walking.html crank walking
https://ls1tech.com/forums/generation-iii-internal-engine/594995-new-motor-keeps-dying-help.html crank sensor
