Rod choice
Old Jun 22, 2006 | 02:12 AM
red90cobra's Avatar
Default Rod choice
I got a iron block bored 4.04 with a 408 piston with a stock crank. What length rod do i need?
Old Jun 22, 2006 | 02:20 AM
DeltaT's Avatar
What's your target power and use? Just as important, how fast (rpm) do you plan to spin it to frequently?
Jim
Old Jun 22, 2006 | 03:14 AM
red90cobra's Avatar
7000 or more depending if I have to and target hp would be 900 rwhp
Old Jun 22, 2006 | 03:15 AM
red90cobra's Avatar
6 speed
Old Jun 22, 2006 | 03:36 AM
SuperZ's Avatar
900 rwhp and over 7k rpms??You need to go with a billet rod.I like the Lunati Pro Billets and ive seen the Howards to big hp as well.
EDIT sorry i just realized i didnt evan answer to question you asked.
Old Jun 22, 2006 | 11:39 AM
LTLHOMER's Avatar
Eagle H-beams here and no problems...8k rpm all day.
Old Jun 22, 2006 | 12:00 PM
red90cobra's Avatar
it's cool. I need some ideas.
Old Jun 22, 2006 | 12:01 PM
red90cobra's Avatar
what kind of power are you making?
Old Jun 22, 2006 | 12:06 PM
LTLHOMER's Avatar
It made over 750 to the tire on 17 lbs on w2w's mustang dyno through a th400. And that was only revving it to 7k. They were actually Derty's old rods too.
red90cobra's Avatar
also if it makes 900 before 7k then i wont spin it that high
Old Jun 22, 2006 | 12:07 PM
red90cobra's Avatar
so can anyone recommend a length
Old Jun 22, 2006 | 12:18 PM
1936FordPU's Avatar
Let me get this straight here..
You have a 4.04 bore in the block...But yet the pistons are a 4.030 for a 408 correct? A 408 uses a 4" stroker crank and I believe the piston pin is offset a little so that piston would only work with the stroker crank...Correct me if Im wrong.
It looks like you are building a 371CI motor if you do get to use that piston you have.
Old Jun 23, 2006 | 12:34 AM
red90cobra's Avatar
sorry they are 4.04 pistons.
Old Jun 23, 2006 | 12:35 AM
red90cobra's Avatar
I believe it's do able with the stroker piston. here the thread
https://ls1tech.com/forums/generation-iv-internal-engine/524413-forged-boost-6-0l-364-w-6-3-rods-402-pistons-impressions.html
