cam vs cam vs cam
i look to 3 cams
1-TR224/224-112
2-Texas Speed 228R
3-Texas Speed 224R
the Comp 921 Valve Springs & Pushrods will be come with cam.
which one the best for give me best acceleration at steest
<Roll Racing 30MPH>???
my mod camaro a4 '98
SLP lid / LS6 intake / SLP LM1 / TransGO / B&M superCoolr / 3.23 /
Pacesetter Lt's / Stock head / Stock converter /
Q: what is the different betwen the 112 LSA and other LSA 110 or 113 114???
Personally i would take the 228...everyone wants bigger so i would go 228 i'm not a fan of thunder cams personally and i know of the lobes and cam profiles used by texas speed. Futral is another excellent option IMO... but anyways
the differences between the LSA's will determine the height of the powerband for instance a 110LSA would be like 6500 and peak torque low in the RPMs 3500-4000... and the 114 would be like 6750 peak torque in the 5000 range.... wider LSA will effect Valve overlap and create less aggressive idling
best way i can explain it for the newb's
) go 114 you want the infamous TSP sound? go 112 LSA. Really there would be no diff, but in your case i would install the 114LSA only due to the stock converter Trending Topics
My suggestion? Get a converter first, then a cam later. If you absulutely refuse to do it this way, then go with a smaller cam with a narrower LSA (that has hope of making better low and mid-range power). You have no idea how bad you're going to get smoked by cars with stock cams running high stall converters (and I'm talking about from a roll!).
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
what the you suggestion?
214/218 .600/.590 110LSA +2 (Comp XFI lobes)
This cam will give you 8.4:1 dynamic compression with a stock motor, which is essential when trying to maximize area under the curve. Also, the overlap at .050" is only -4 degrees, which will keep the idle managable so you won't be up against the brakes 24/7. Also, the mid-range torque will be massive which is just was a vehicle with a stock converter needs.
But again, this is just a bandaid to the problem of not running a high stall.
the TC was installed yesterday TCI SSF 3500 2.5 STR
and still stock head
now time for cam my gols is the same <Roll Racing>
what do u think about this
TSP 233/ 233 .595/.595 112
<for stock head and at future mybe 75 - 100 shot>
232/240 .595/.609 110LSA +1 advance
This cam will make peak power at 6300, but it will pull easily to 7000...just what you want when racing from a roll. Just save up for that tranny rebuild.
i was rebuild my tranny before with TCI clutchs.
this big cam for me and the Springs is Comp 921
i want cam & Springs & Pushrods = 600$ like the package at TSP OR TR
what do u think when i get like this 232/236or238 .595/.598or.600 110LSA +1
note: the NOS <maybe> i'm not sure.
