will I pass emissions with this cam
Old Jul 20, 2006 | 07:30 AM
SLPSS01's Avatar
Default will I pass emissions with this cam
Like the title says, Speed Inc's SI007 cam is going in
(228/222 .588/.581 on 114.5lsa)
will I have any trouble passing emissions here in IL. which is the
OBDII test only.Only other mods on the car are long tubes w/ no air & no cats, and a tq converter.
Old Jul 20, 2006 | 07:59 AM
1baddls1's Avatar
if they only scan OBDII like NY as long as you do not have ur CEL on/any codes stored in the system you should be fine
Old Jul 20, 2006 | 08:01 AM
1baddls1's Avatar
only thing to worry about is visual part of the inspection (if they do it) which most dont here in NY
Old Jul 20, 2006 | 01:23 PM
PREDATOR-Z's Avatar
No as long as you erase all codes and you pass visual test (for catalitics or what looks like them )
Old Jul 21, 2006 | 03:19 PM
Bill Bowling's Avatar
I have a special tune that I use just before going for inspection.
Bill
Old Jul 21, 2006 | 03:34 PM
jermstyle's Avatar
I think anytime you go to have your car inspected and it’s stumbling on a cam they are going to think twice about passing you. Unless you can find a ‘cool’ shop.
Old Jul 21, 2006 | 03:41 PM
lt1formula2000's Avatar
I wonder for OBD-II testing do they even start the car or do they just hook up there scanner and turn the key on. I'm in Oklahoma we have no inspection so I was just curious.
Old Jul 21, 2006 | 08:04 PM
Michael02hawk's Avatar
If IL does a sniffer test, no, you'll probably fail the snif!
Like everyone else says tho,a tune can easily handle the ODB2 portion, and if you have cats, thats cool.
But the sniff is a no go. With 228/222, you'll need an LSA of 115.5 or higher to pass sniffing.
Old Jul 21, 2006 | 08:25 PM
02 Camaro SS's Avatar
I passed the sniffer with a 228/222 114LSA when NY still did it. If it's only OBDII then make sure you're not throwing any codes and you have cats (or someone who's willing to look the other way on that aspect of the inspection)
Old Jul 22, 2006 | 06:57 AM
NY never sniff tested.
114LSA on that cam will fail a sniff test.
