What you think of this cam?
What you think of this cam? For 408!!
I have a 408 with this cam- 244 248 612 615 113lsa with 4 degrees ground in. Do you think this is to much overlap? I`m just trying to trouble shoot something. Thanks for any comments! Car in sig!
Your overlap is not that bad. Get it SD tuned if you haven't already and watch it drive like a dream.
On a side note, you have too much bias to the intake side with that much advance; retard that cam 3 degrees. You have an A4, so who cares about power at 2500 RPM? The later IVC will hurt power down low, but will help up top (even if it fights the FAST a bit, it's not way out of line).
Plus, when you bring IVO and EVC equal, power will carry a lot further on the top end, and the retarding of the cam will lower the EVO, which will increase midrange power. All of those things can't hurt you, plus it will lower your overlap a tad.
They had 4 degrees ground in the cam from comp to set it dot to dot. Is that not good to do? Seems from what you said its to much! Is this correct! Up top is where I`m really hurting right now. She doesn`t pull real good up top. Just down low.
No doubt retarding the cam will shift your powerband higher, but you might have some other issues going on if it falls off like you are saying. You might have some valve control issues perhaps caused by inadequate springs or lifter pump up actually holding the valves open up top. If you have not already, you may also check to make sure you are not getting any knock up there and losing some timing.
I'd personally run a tighter LSA and leave out the advance. If your working with what you have, then just retard the cam 4 degree's. Like Jake said, it's to much intake biased right now. Although I don't think it will help much because I believe you have other problems. Under no circumstances should that cam peak at 5400 rpm's. Something else is wrong.
