What cam with TSP Terminator heads?
That's all nice, but reading what cam gurus like Patrick G have said, the MS3 is good for peak numbers but not so great for power under the curve, compared to even the Trex. That's the reason I'm asking. Peak is nice, but I've gotta actually drive this sucker.
MS3 is the way to go, 490 is nasty power for a stock cube engine. If you could flycut i would say go with an MS4 cause i bet that would net over 500rwhp with the correct supporting mods and a good tune.
Originally Posted by MavrikTA
Ive been talking to TSP, and oddly enough, they say that the MS4 is MORE streetable than the MS3. It has more midrange.
Yeah the MS4 has the new LSK lobes on it which bring the power in a little bit earlier. It is a bigger cam but with those lobes the power is more spread out instead of just at high RPM's. But with the edelbrocks on there with the MS3 the power comes in a lot stronger at lower RPM's then when the cam is used in a cam only set up. The 200cc runner's gave the car incredible throttle response as well.
I would stick with the cam you have in your sig unless you are only after peak numbers. You can have the heads milled so you can run some decent compression without having to flycut the pistons. If it's more of a street car this is what I would go with.
With a m6 he could easily drive a larger cam, and with those heads its gonna have pretty good midrange power. So IMO going with a larger cam would still keep it a considerably driveable street car for that kind of power.
the torquer v3 is there....maybe not on the site, but we have it....just call and whoever answers should be able to give you the scoop on it. the 220cc terminators are in the works, i'll let you know as soon as im told when to expect them
7 Second Club
Just additional some food for thought....
Cartek has always had alot of fast corvettes(mid 10s)
Most of those corvettes were on 224/228
Almost all of those cars were shifted ~6800
Every 6 degrees you increase duration I believe you raise peak power 500rpm
You do the math
Bottom line if you have the ***** to run a big cam that makes power after 6k you better have the *****/setup to shift 7k+ or your gonna leave power on the table.
You do the math
