Got my Car back H/C 347
Got my 2000Z28 back on Saturday from Tick Performance in Mt Airy NC. The engine is completley rebuilt, 347 with mahle -4cc pistons balanced rotating assembly with stock rods and crank, TSP PRC LS6 heads with valve job milled .020, cometic .040 gaskets and the Tv. 2 cam on a 112+1, comp prs, ls6 oil pump etc.
The car feels Insane and sounds like a nascar with the long tubes, off road Y and slp loudmouth, I cant stop drivin it and I cant wait to see what it does on the track and the dyno
Congrats on the new set up. Should of had them install a LS7 clutch while they were in it. I just got mine back from Williams Performance in Mooresville and had to add a clutch cause I knew my LS6 one would be done in a matter of weeks.
Thanks yall i will try to get a soundclip up soon and hopefully i will get it tuned in a week or so maybe ill have some numbers soon and let yall know how this setup works. A centorforce clutch was installed while it was down so hopefully it will hold up.
