cam and bolt on setup
Old Aug 24, 2006 | 03:49 AM
Ws6man2000's Avatar
From: Ft lewis,Ft sill and thats all i hope.Katy texas
Default cam and bolt on setup
when i get back from iraq here is what i want to do
car is a 99 formula with 106k on clock and its an a4
tsp ported oil pump
ms4 camshaft
valve train kit from tsp
pacesetter lt with x pipe
42lb injectors
ls6 intake
asp pulley with overdrive alt pulley
3800 stall
tubular lower control arms
panhard bar
tranny cooler(not sure what size to get)
is this a good start? I know i am missing some things this is just to get started and, please dont be an *** when you point out something i have done wrong just looking for help
Old Aug 24, 2006 | 08:14 AM
The PAT WS6's Avatar
i bet u cant wait. thats alot of **** $$$$
Old Aug 24, 2006 | 08:32 AM
jamesSS's Avatar
sounds like your going to have a lot of fun. your not going to want to go back and leave that car again. i hope you can find a good place to store your car if you have to go back over seas. ive seen some car lots on a base near san diego and there cars turn into **** just sitting there. anyways, your setup sounds solid. only thing im not seeing would be a lid, your choice of muffler for the x pipe, and you can port your own TB, and your going to need a really good tune, especialy after your cam swap. either way, your going to have a kick *** car.
Old Aug 24, 2006 | 12:22 PM
Ws6man2000's Avatar
thanks, well i get out of the army i have done 2 deployments before i was 21, so i need to get out and do something else, now will the ms4 work on stock heads i have the money to get what ever i need just not sure if this cam is made for stock heads or aftermarket???
Old Aug 24, 2006 | 01:40 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
They should work fine with stock heads if they have not been milled. Sending to the ole internal section.
Old Aug 24, 2006 | 01:53 PM
BREAKPARTS's Avatar
Hell Yeah Thats A Perfect Start, You Got Some Miles On Her But Thats Ok .run The Cam And Drag Radials. And When You Rebuilt Her, Do Rod Bolts And Badass Heads.that Cam Is Very Healthy
Old Aug 24, 2006 | 01:54 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Are you running an MS4?
Old Aug 24, 2006 | 02:40 PM
ArrestMeRed99Z28's Avatar
I think with a cam like the MS4 you'll probably want some gears (at least 3.90s) and a stall more around 4k. There is a 9 page thread on the MS4 cam if you just do a search in this section. If you are planning on doing more to the car in the future (Stroker, N2O, FI) then you might as well swap in a 12 bolt or 9 inch rear end now.
Old Aug 24, 2006 | 02:47 PM
Slacker's Avatar
add these to your list;
Some MT drs & possible a roll bar
be safe
Old Aug 27, 2006 | 04:17 AM
Ws6man2000's Avatar
ya everything i listed was just to get started, but thanks for all the input would you suggest i rebuild the motor right away or wait cause i am going to be replacing just about everything that i can replace,pushrods,springs,valves and prob lifters how big of a stall should i get and what company should i go through to get it???
Old Aug 27, 2006 | 08:10 AM
Beasst8's Avatar
Yeah, Im doing gears with my MS4/Heads. Thats going to be a strong setup. Gonna feel like a completly different car. I cant wait to get mine going again.
Old Aug 28, 2006 | 04:16 AM
Ws6man2000's Avatar
thanks on the heads up about the 9 page thread, search is wonderful and it helped me decided to def go with 4+ k stall as you suggested, also with the 12 bolt i am not sure what gear ratio i need to get????
Old Aug 28, 2006 | 01:35 PM
If you drive your car on the freeway a lot and gas mileage is a concern you may want something like 373s if you just go to the track, beat the hell out of it and drive it home then you can go crazy with something like 430 gears, the 430s will also do well in the burnout contest . But it really depends on your goals, I would find someone else with an A4 and the MS4 on this forum and ask them how they like their gears, what 60 ft time then run and what kind of gas mileage they get.
Old Aug 28, 2006 | 01:38 PM
Ws6man2000's Avatar
ya gas will be really important, cause i am going to be driving a pretty far distance after i get out, washington state to texas i dont want to have to fill up every 200 miles
Old Aug 28, 2006 | 02:27 PM
SVT THIS's Avatar
Get a 4400 stall-I have a 4400 stall and love it. I daily drive it everyday with 2.73 gears. I am going to be getting 4.10s soon enough to tighten her up, but even now it is fine. You can make it easier to drive by setting the stall lockup at like 25mph.
Get 4.10s, 3.90s or 3.73 gears-If you have a 2 series rear end (factory 2.73 gears) and do not care about mpg (which you shouldn't with a big stall and cam) then go with 4.10s. Everyone who says 4.10s are to much are the ones with 3.73s. Everyone who says go with 4.10s have 4.10s. I trust the guys running the gear to tell me whether or not its okay. If you have a 3 series carrier (factory 3.23 or 3.42 gear) you can get a happy medium between 3.73s and 4.10s by getting 3.90s (available at Thunder Racing). If for some reason you care about gas mileage, then go ahead and get the 3.73s.
I fill up less than every 200 miles with stock internals...
Old Aug 30, 2006 | 03:15 AM
Ws6man2000's Avatar
ill try with stock gearing see what i get mpg wise, then when i get back to texas prob swap it out
