View Poll Results: MS4 OR TREX
MS4
157
58.80%
TREX
110
41.20%
Voters: 267. You may not vote on this poll
MS4 VS Trex
Old Oct 31, 2006 | 10:24 AM
  #41
BADSZ28's Avatar
Oh and the TRex loves juice too. I got 470/563 on a 85 dry hit.
Old Oct 31, 2006 | 02:39 PM
  #42
Cam02ss's Avatar
another vote for the t rex. i made 463/402 to the wheels on a mustang dyno running through FLP long tubes out LM exhaust. i switched to QTP longtubes and 3" dynomax bullets dumped and made 457/396 on the same dyno. first dyno was in may when the air was cooler than the 2nd dyno..which was made in july. gears are a must...my t rex loves the 4.30s...
Old Oct 31, 2006 | 02:48 PM
  #43
BADSZ28's Avatar
No way in hell that was with stock heads? What gears were you running when you pulled those numbers? Were those weather corected?
Old Nov 1, 2006 | 09:55 AM
  #44
DanZ28's Avatar
His sig says GTP S2+ Heads. But was this for sure corrected numbers and on a Mustang Dyno?
Dan
Old Nov 1, 2006 | 10:19 AM
  #45
BADSZ28's Avatar
Nice numbers for a heads/cam car for sure on a MD. I saw his sig, but he could have listed numbers prior to heads. He did not specify. I am going to say that has to be with heads.
Old Nov 1, 2006 | 01:48 PM
  #46
04gtoBMXracer's Avatar
t-rex is proven...holds the cam only record,need to say anything else?
Old Nov 1, 2006 | 02:29 PM
  #47
Cam02ss's Avatar
those numbers were on a mustang dyno, were with the heads listed in the sig and were weather corrected. the only difference was that i had 4.10s instead of the 4.30s. and i am selling this engine to do a 408 lol
Old Nov 1, 2006 | 03:29 PM
  #48
DanZ28's Avatar
Have you dyno'd on a dynojet or a different dyno? Those numbers would be in the 500+ rwhp area on a dynojet? I have only seen those kind of numbers on some all out motors from sponcers so far. Do you have track numbers? Just add a 50 shot and your at 408 numbers, lol.
Dan
Old Nov 1, 2006 | 04:40 PM
  #49
Cam02ss's Avatar
no i havn't on a dyno jet yet nor have i run at the track yet. yea we had to fly cut the pistons to fit the cam in there but it runs bad ***. i'm planning on doing a 150-200 shot with the 408 once i get the motor. i dunno if the 4.30s robbed me of alot of hp or not but the car works alot better with them.
Old Nov 1, 2006 | 08:12 PM
  #50
CockerKid009's Avatar
let me be the first to admit i am ignorant. please forgive, i'm learning. I understand the trex can make the most power, holds the cam only record and what not - BUT i'm not a drag racer, the closest quarter mile is 2 1/2hrs. from me. What i'm looking for is an extremely reliable setup that can still make some good numbers and most importantly some more fun behind the wheel. How are your guys' transmissions holding with these high reving cams, not to mention the stock 10 bolt which speaks for itself. What i want to do is some 'budgeted' mods. I plan on MS4, which makes more of it's power down low (so i've heard), also a 3200 or so stall, and maybe later on some heads. I'm just curious as to how everyone's cars are holding up drivetrain wise. I also plan on doing some Pacesetter Lt's with TSP true duals at the same time. Talk about a wake up for the car. is there anything i need to know before i do this - such as your stock 10 bolt will never hold, or your tranny will take a dump after XXK more miles?
Old Nov 1, 2006 | 08:52 PM
  #51
SuperSlow02's Avatar
why just stick to a proven cam...let the MS4 numbers come out from the track..who knows what will happen. Just research the damn thing, contact TSP see if they have any track numbers yet...etc..etc... Im sure it was the same way when the T-Rex first hit the market.
Old Nov 2, 2006 | 04:37 PM
  #52
Cam02ss's Avatar
my friend just got the ms4 cam when all of us suggested that he get the ms3...once again a proven cam. he wants to add heads eventually so we'll see if that turns into a nightmare or not. now..i had to flycut to make my h/c work so i'll be interested to see how it goes with a .649 lift or whatever the hell it is
Old Nov 2, 2006 | 06:32 PM
  #53
blue2000Z28's Avatar
Ok here ya go. Transmissions: If your an A4 and you have a HUGE cam get a BIG converter. Stock A4...GOOD BYE with almost anything done especially a cam, stock m6..dunno never had one but im sure they arnt to bad. Stock 10 bolt: A4 and a big stall with stock gears(which you CANT run with a cam that size) youll be ok. M6....well hell youll break a 10 bolt with sticky tires. A4 with converter and gears. A friend of my'n had a a4 built with 4600 converter and 3:73's. Did good. As far as holding up, well thats a problem, because youll only here about the negitave side of EVERYthing on here. Hope this helps..OH also, in the performance world, if you want to go fast then your going to have to pay and if might not last to long. Good luck with the cam and have fun with it!
Old Nov 2, 2006 | 09:31 PM
  #54
1 SiCk Ws6's Avatar
Originally Posted by SSilverSSurfer
i dont consider them even comparable, the TREX is just plain nasty
Could not of said it better myself. hit it right on the head.
Old Nov 2, 2006 | 11:11 PM
  #55
i thought lasthawk02 aksed what cam is better?
Old Nov 7, 2006 | 01:28 PM
  #56
KONG's Avatar
I just read a magazine, I believe the latest GM High-Tech and the MS4 made awesome power in an LS1. They picked up 82 hp on a stock headed LS1. It was a safe tune on 91 octane. I believe it will ultimately be a more street-oriented T-Rex type camshaft. It has potential, people just need to put to the test at the track. In the end just pick what works with the sum of your parts.
Old Nov 8, 2006 | 02:03 PM
  #57
Killer_Bluebird's Avatar
I gained 40rwhp with Stock Heads and Stock Exhaust Manifolds + ORY and borlamouth. It dynoed 385rwhp. I'm installing longtubes this weekend so I will see how much more I will pick up. But I'm figuring on around 20rwhp from the headers alone so that would put me in the 405rwhp+plus watever the cam will gain from better exhaust considering that right now my car is severely limited exhaust wise since the MS4 has quite a bit of overlap (though not as must as the Trex). I didn't vote but I'll do after I can post a graph. As far as drivability is concerned it drives pretty good, I've driven it to work a few times with no issues although I'm still tweaking my idle tuning. Right now the car idles at 950rpms once I get surging better under control I might go even lower. It sounds wicked at 800-825rpms.
Old Nov 9, 2006 | 05:47 PM
  #58
KONG's Avatar
I have been doing research on the MS4 and I am seriously considering it. I just think it would be a good choice for me because my firebird is heavy. I have heard and seen nothing but good thing from it. Nice numbers without headers bro.
Old Nov 10, 2006 | 10:32 AM
  #59
DanZ28's Avatar
I haven't seen any good track times from it yet, I'm sure they will come though hopefully. Those are good numbers without headers and your right about picking up another 20 when you put them in, Congrats!
Old Nov 28, 2006 | 12:37 PM
  #60
CNTLSE 1's Avatar
TSP needs to take this cam to the track and let us know what is up!!!!!! I'm tired of waiting.
