T-rex and 4400 stall Question
Old Sep 20, 2006 | 09:55 AM
import slayer's Avatar
Default T-rex and 4400 stall Question
I am running a Trex cam and I just ordered a Yank PT 4400 I have a stock bottom end ls1 and the rest of my mods are in my sig. What should I set my rev limiter to and what RPM's do you think I should be shifting at.
Old Sep 20, 2006 | 10:00 AM
HaulinHawk's Avatar
Not a T-REX here ,but i am shiftin 6800 rpm ,limiter 7000 .No probs here,stock bottom.What are your hp and tq #,s,dyno graph?
Old Sep 20, 2006 | 10:28 AM
I still have not dyno'd it yet but I will when the converter is in and my tranny is rebuilt. You said no problems with your set up but my question to you is is your car a DD because mine is
Old Sep 20, 2006 | 10:34 AM
HaulinHawk's Avatar
It was a DD for about 6-7 months and i was riding it hard at the track .Not a DD now.
Old Sep 20, 2006 | 10:54 AM
PREDATOR-Z's Avatar
The best way to determine that is to dynotune and read the graph.
Knowing the stall shift extentions from track runs, and comparing that info with the graph, you then can decide which shifting point will keep the highest average HP.
That will be your shift point and limiter should be st at 300 rpm higher.
Old Sep 20, 2006 | 12:32 PM
thanks for the advice
Old Sep 20, 2006 | 12:54 PM
SVThis's Avatar
ok i asked u somewhere else and i dunno fi u answered but did u actually run your car with a T-rex and 2800 stall? if so how did that work out for you?
Old Sep 20, 2006 | 04:21 PM
s346k's Avatar
with a 2000 shortblock, i wouldn't spin the engine past 6,600 rpm, due to the weak rod bolts. should you replace the rod bolts AND your shorty headers with longtubes, i would say shift @ 7,100, limiter @ 7,300. the t-rex LOVES free flowing exhaust and RPM. the shorties are probably hurting your ability to carry peak power.
the best method would be to dyno it and use the graph, as previously stated. spin it until it stops making power, then shift...whatever be the rpm.
Old Sep 20, 2006 | 04:25 PM
bjamick's Avatar
OMG you will prob get tired of that big of a stall really quick being your DD but i would shift at prob round 6500 and set limiter at 7
Old Sep 20, 2006 | 04:50 PM
__________________
I could tell that the top end was not there with the 2800
Old Sep 21, 2006 | 12:25 AM
PREDATOR-Z's Avatar
That is the effect of the exhaust and LS1 intake, not the stall.
The stall would affect low >midrange area. A 2800 stall is more efficient than a 4400
