Floating Valve? Valvespring broke? I dont know! need help
I recently added a cam and headers and the car was running fine. Some issues with backpressure, since i was running no cats and an open cutout. But i went true duals and fixed that problem. Then i just added an ls6 manifold and its running fine. However, recently the car has been acting up. My 1-2 shift seems fine, but then my 2-3 shift acts up, when it reaches higher rpms around 5300+ the car seems to bog and want to cut fuel and when it reaches its shift point, theres a delay and theres popping sounds coming from the exhuast. Its really bad when im crusing on the highway and gun it, its a dog becuase of these bogging and delay, its hard to explain, and im haviing trouble trying to figure out what exactly it is. My friends are thinking i might have a floating valve?
Some dude told me that he had a similiar problem, however, it was becuase his cats were clogged up and a 02sensor was bad. I dont have any cats and I think my 02's are good becuse its not throwing any codes
sounds like a Bad miss fire to me. I had the same thing happen to me in V6 contour. I bet if you run a scan tool there will be a code there. When i had a miss in my other car (and it was a bad one it sounded like a 9mm was going off every few secs) there was no light but there was a code there. double check you plugs and wires first and run a scan tool
As stated above, ohm the spark plug wires, and check the plugs for cracks in the porcelin, or bad electrodes. Sounds exactly like what I had. New wires fixed it. But ohm them first, that is definitely measurable.
